Thread: 3.2 - alternator voltage fluctuates
    Mar 2007
    Finland
    Default 3.2 - alternator voltage fluctuates
    Hi!
    Noticed today that the alternator voltage fluctuates/ripples between 13.0-14.3V when idle and stationary. This can be seen on the interior and exterior lights also, brightness changes quite rapidly.
    I have already changed the battery, but it didn't help.
    What could cause this fluctuation to the voltage?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Maybe a failing alternator?
    Mar 2007
    Finland
    Obviously
    The voltage regulator is most likely embedded in the alternator.
    But is there anything else that could cause the fluctuation to the voltage (f.ex. CIM, control modules)?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Is it ok and steady when rev'd? The Vec's electrohydraulic power steering pump is notoriously hard on the alternator.
    Mar 2007
    Finland
    I have to check the voltage with revs. The fluctuation occurs at idle and "hands off" from steering wheel (I was measuring the voltage directly from the battery with multimeter), so the PAS pump is not in use, and does not cause this.
    Car is 9 years old and has just reached 100000 miles.
  1. What voltage should the alternator be producing (3.0 V6 CDTi)?
    By ph67 in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2013, 14:37
  2. Vectra 1.9 CDTi 150 Alternator / battery voltage
    By trucklord in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2012, 10:06
  3. Temperature fluctuates
    By evaldas in forum Engine & Drivetrain
    Last Post: 20th April 2012, 23:16
  4. Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    By Jedi in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 18:17
  5. Alternator Voltage
    By Godzilla in forum Engine & Drivetrain
    Last Post: 10th June 2010, 21:47
vectra c 3.2 v6 alternator voltage at idle
alternator vectra 3.2
