Results 1 to 3 of 3
Thread: my heater wont work is it the blower
    Oct 2012
    birmingham
    Default my heater wont work is it the blower
    hi well when i got the car the heater worked on setting 4, now none work not even the heated rear window, i have changed the control panel and u can now hear a click when u turn the heaters on but no air.. sounds like the blower is stuck to!!! wud this be the resistor or the blower ????
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Have you checked the fuse? Could be a resistor fault. If you remove the resistor completely, it should work on Speed 4 only.
    Has the fan been noisy before it stopped? (indicating it would have been sticking)
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    classic resistor fault symptoms! It's a cheap and easy fix.
  1. heater blower not doing its job
    By coylo5 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 14:58
  2. Heater / Blower Fan
    By chris2464 in forum Bodywork & Interior
    Last Post: 5th January 2012, 13:30
  3. heater blower
    By bootneck85 in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2011, 00:40
  4. Heater blower!!!!!
    By mitch in forum Electrical & ICE (including SatNav)
    Last Post: 19th November 2010, 00:15
  5. Heater Blower
    By Woolly in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2008, 18:12
