Thread: Another problem
    Regular Member neil52's Avatar
    Oct 2012
    leeds
    Default Another problem
    woke up this morning car wouldnt start, it was ok last night,wont turn over just a single click from engine have tried a jumper pack no joy still same have just been and bought a new bosch battery still same, any ideas were to go now would be appreciated
    Sep 2010
    wonder if its an immobiliser issue?.....
    Oct 2012
    leeds
    that was strange gone out and its started ok!!!!! im not very technically minded
    Jan 2012
    South West
    Engine : 2.2 Direct
    Mileage : 37000
    Starter motor jammed perhaps , or doesn't that happen anymore , used to on my old Fords
    Oct 2012
    leeds
    I think its an immobiliser problem cos the key fob isnt working again but car starts ok. Think id better go back to were i bought it and hace a chat with them
    11 Post(s)
    If it's immobiliser related, then depending on the age of the car you'll either have a padlock symbol appear in the rev counter LED display, or the car/spanner light will flash on and off.
    11 Post(s)
    Quote Originally Posted by neil52 View Post
    Huh? Just re-read that in case I misread it the first time.
    If it's immobiliser related, then the car wouldn't start.
    By "the key fob isnt working again" are you in fact just referring to the central locking not working? Have you tried changing the fob battery?
    Regular Member tiimi's Avatar
    Sep 2012
    anglesey, uk
    i had a problem with my car being really hard to start. after reading a few posts, i started to start my car with clutch down. starts first time now really easy
    Oct 2012
    leeds
    it started the other day not opening or closing doors via key fob so i replaced battery read up on here saying to insert key turn to first notch then press door open nothing happened after about 20 mins it just started working i thought it was what id done. then the next day the key fob opened the doors but the car wouldnt start. turned ignition just one click coming what sounded from glove box side and then nothing all, lights came on when turning ignition so tried charging battery still nothing so i went and bought a new car battery still wouldnt start then after about 20 mins it started, then this morning key fob not working but car starts. just one thing when i open the drivers door with key when fob not working the alarm goes off till i put key in ignition and start. so im just presuming it could be a immobiliser problem
    Oct 2012
    leeds
    just got home key fob still not working but car starts ok have to use key to get in though
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
