Results 1 to 10 of 11
Thread: spanner light while under acceleration help
    Nov 2010
    Yorkshire
    Vehicle : Vectra Cdti 150
    Trim : Sri
    Engine : 1.9
    Mileage : 82000
    Default spanner light while under acceleration help
    Hi guys hope someone can help me out. Bought my Vectra cdti 150 preface 4 weeks ago and got a warranty with it, since then its been in the garage for new inlet manifold due to the swirl bar fault,new alternator as my power steering failednew thermostat and just got it back from having the duel mas flywheel done, which wasn't covered under warranty. It went to the garage due to the spanner light coming on while I was accelerating which in turn lost power. So got it back yesterday ( after a week ) asked the mechanic if everything was fine and they said yes. Fetching it back home yesterday and it now seems down on power,it has a rattle to it which wasnt there before and the spanner light came on again. Any help will be gratefull as the garage has had the car longer than I have and its 30 miles to take it to the garage for the warranty and Im now getting fed up
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Stewsy
    There are far to many possibilities for what is causing your spanner light to come on .
    You will need to have the fault codes read to diagnose what the problem is likely to be
    Just ask on here if there is anyone near with a code reader who may be able to help you out in this matter
    but in the mean time check all your hoses for tightness also check your vacuum hoses have been connected properly .
    garages are no saints and are more than capable of puting a car back together wrongly (from personal experience ).
    and still loving it
    Nov 2010
    East Midlands
    Trim : design
    You have obviously had most of the more common problems sorted by the sound of it - but if your not happy with the car you would certainly have good grounds to take it back and ask for a refund - if they have had it more times than you it isn't 'fit for purpose' - although if you have gone to the expense of replacing the flywheel it might be worth seeing it through now. As stated above you need a diagnostic check to give you some indication of what's causing your latest problem - good luck with it.
    Nov 2010
    Yorkshire
    Trim : Sri
    Engine : 1.9
    Mileage : 82000
    My mate who is a mechanic told me the flywheel was on its way out and also put his code reader on and it came up with P0960 Rail Pressure Control Circuit Open, P1125 Throttle Actuator Circuit Open. So when I took it to the garage I told them that the flywheel was knackered and showed them the codes as I took a photo of the code reader displaying the codes and they said that they would sort it. Got the car back yesterday after a week in the garage and the spanner light is still coming on but there are no codes stored..the spanner light comes on under acceleration which causes the car to lose power for about 10 seconds when i take my foot off the accelerator then goes off again..
    Nov 2010
    Yorkshire
    Trim : Sri
    Engine : 1.9
    Mileage : 82000
    Just had a go up and down a bypa near us and after 10 mins the spanner light finally came on...so pulled over as quick as i could and read the ecu via opcom before the spanner light went off again and the fault code is now P2279-11 Intake Air Leak Detected..any idea where I should be looking guys ????
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Check the air box and pipework from the air box.
    Also check the boost pipe on the right hand side for splits.
    And the EGR gasket may be leaking a little as well.
    HTH
    Nov 2010
    Yorkshire
    Trim : Sri
    Engine : 1.9
    Mileage : 82000
    Checked all pipe work and all looks fine, the boost pipe is a bit spongy though, is this normal ?? I am going to take off the egr over the weekend and give it a clean see if that works...thanks for all the info guys
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    http://www.vectra-c.com/forum/showth...ult-code-P2279
    post 6
    try to strip the Solenoid side of the EGR to resolve this
    Nov 2010
    Yorkshire
    Trim : Sri
    Engine : 1.9
    Mileage : 82000
    All sorted now, it was the turbo intercooler which had a hole in it and also the turbo was fubbered. Just got it back from garage and everything done under warranty so happy bunny
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  3. Jerky acceleration / Car with spanner light
    By danman487 in forum Engine & Drivetrain
    Last Post: 8th July 2010, 14:31
  4. engine light on,lacking acceleration,2nd and 5th gear manual mode
    By myvauxhall in forum Vectra C / Signum Troubleshooting
    Last Post: 7th April 2009, 10:58
  5. CDTI 150 Spanner on Acceleration
    By b-e-r-t in forum Engine & Drivetrain
    Last Post: 8th September 2007, 21:25
spanner light comes on loss of power
