Thread: Engine tempature
    Oct 2012
    birmingham
    Default Engine tempature
    Hi, i have an 06 vectra sri 2.2 direct, it had a full service yesterday, i have never noticed it before but the engine temp gauge kept on moving between 85-95 whilst driving, mainly sitting on a little up hill and then again sitting on the slope going down a hill at some lights, it usually just sits on 85 and doesnt move, what would cause this? is it a common problem or nothing to worry about?
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    mines sits at 86 bang on all the time maybe creeps a couple degrees when stationary
    have you checked your fan is working correctly
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    I have the same car buddy and mine just stays just under 90 all the time, 95 when sat in traffic then goes back down when moving. Might be a thermostat on its way out not sure tho buddy. Hopefully someone will be along soon.
    But you would be better posting this in the correct section buddy (Troubleshooting - Engine and drivetrain) as more people will look at it.
    Oct 2012
    birmingham
    No i havent, how would i check to see if it working properly?
    Oct 2012
    birmingham
    I would but it took me ages to figure out how to post it on here lol
    Jul 2012
    Scottish borders
    tbh i dont even think your fan would kick in whilst driving, the thermostat should control the heat along with the wind while driving
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Don't worry the sweep up police will move it for you good job we are about isn't it
    p.s. the first one is free the next one is a free deletion lol
    Oct 2012
    birmingham
    hahaha cheers sorry, just signed up to forum,lol, yea usually just sits just under 90, thanks for help tho =)
    Quote Originally Posted by mattbanagan View Post
    Mine started doing that, and I could pull the engine temperature right down by putting the heater full on. The cooling fan was forever coming on and off as well when the temp roase above 90 deg C.
    Fitted a new thermostat, along with flushing the system and putting in new antifreeze and now the gauge tends to sit around the 82 to 86 mark, and gets warmer quicker, and doesn't make the engine go cold when putting the heater on.
    The standard stat is rated at 82 deg C. Since changing the stat the cooling fan hardly comes on anymore.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Engine tempature
    By mattbanagan in forum West Midlands (RO - jaguser)
    Last Post: 31st October 2012, 22:30
  3. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  4. Replies: 35
    Last Post: 5th May 2012, 15:32
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
