Thread: Front subframe mounting bolt
    leics
    Default Front subframe mounting bolt
    I've just changed the DMF and clutch, when I came to bolt the subframe back up the ns rear mounting bolt went really stiff as I was screwing in, I've took it out and the thread is damaged, seems the thread in the nut in the body has caused it, can this be replaced??? Any other suggestions?? Help!!!
    Dec 2011
    Seaham
    Get a tap and re-tap the thread in the captive nut.
    leics
    Quote Originally Posted by Ben50n View Post
    Cheers, M12 would you know?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Cross threaded on way in.
    As above will need a tap to sort.
    and new bolts can be had from dealer for couple quid
    Dec 2011
    Seaham
    Best way to find out is use a thread gauge. Re-tap the captive nut and either get a new bolt or make sure the thread is good on the existing bolt. Sometimes you can tidy the thread up on a bolt using a good quality nut.
    leics
    Cheers!
  1. N/S Front Subframe mount
    By cookie in forum Suspension, Wheels & Brakes
    Last Post: 1st December 2013, 10:47
  2. brake pipes - engine subframe rear mounting
    By DaveG in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 09:18
  3. Seat belt mounting bolt
    By vectra 120 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2010, 13:24
  4. facelift front subframe help!
    By andrew382 in forum Suspension, Wheels & Brakes
    Last Post: 21st July 2009, 17:59
