Results 1 to 10 of 23
Thread: Question for the IT gurus around here...
    Regular Member sinless's Avatar
    Nov 2011
    Edgware
    Vehicle : Insignia
    Trim : Exclusive
    Engine : Y20DTH
    Mileage : 96500
    Default Question for the IT gurus around here...
    Hi,
    To cut the long story short...my laptop`s hdd is gone with the wind (it may fail soon so windows cannot install on it).
    I have an external hdd (wd my passport) connected trough usb. I tried to open it and put it into the laptop, but as the laptop has sata connectivity, it does not fit into the laptop bay.
    So my curly mind had an idea...what if i try to install windows on the external drive? I connect it to the laptop and try to install on it.
    In bios I can see the drive, as external hdd so i guess it should be allright...or not?
    thanks guys....
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    It should be fine yep. Although slow depending on what USB version it is.
    Try it and find out
    Nov 2011
    Edgware
    Vehicle : Insignia
    Trim : Exclusive
    Engine : Y20DTH
    Mileage : 96500
    it`s usb 2.0...it should be ok, that`s what i thought....but i wanted to be sure....before i damage something.......thanks...
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Run a disc check to make sure its running ok before using new hdd.
    Nov 2011
    Edgware
    Vehicle : Insignia
    Trim : Exclusive
    Engine : Y20DTH
    Mileage : 96500
    the disk is allright..i keept on using it as external drive, as back up. Right now i am transfering all the data on my wife`s computer and i will give it a try.... and let you know !!!
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Whats your long term plan? If its to continue to use the USB drive then to be honest I would just buy a new drive. They are dirt cheap. Maybe even consider SSD as these have got alot cheaper recently
    Nov 2011
    Edgware
    Vehicle : Insignia
    Trim : Exclusive
    Engine : Y20DTH
    Mileage : 96500
    Quote Originally Posted by Ziggy View Post
    I will just use it like that until Christmas, when Santa is going to give me a ssd. Hope so. For the moment i cannot afford to buy anything, although i would, buy i do not have the cash (long story and awkward)...
    I will let you know how it goes! i am just saving some data on me wife laptop (-ish) (samsung nc110)
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Cool sounds like a plan. Should be fine until then. Just dont unplug it by mistake
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Or I could give you the 60gb SATA drive I have
    Nov 2011
    Edgware
    Vehicle : Insignia
    Trim : Exclusive
    Engine : Y20DTH
    Mileage : 96500
    Quote Originally Posted by merikiito View Post
    i would love to take the 250 gigs right now, cuz i need it, but if you belive me i do not have the money for it! I know it`s unbelievable but i am in a rough situation. never mind.....
    as i have found out you cannot install windows on a usb drive....unfortunately....
    here is the reason...i will just have to wait till i have the cash for the drive ...
  1. Question for ICE gurus
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2012, 20:29
  2. Tech question for the IT gurus...
    By macdad in forum The 'Off Topic' room
    Last Post: 11th July 2012, 19:50
  3. question for all the windows 7 gurus
    By hoochydady in forum General Chat
    Last Post: 20th March 2011, 19:53
  4. Only for the Gurus
    By lizard in forum Photoshop section
    Last Post: 23rd September 2010, 15:15
  5. mot gurus
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2009, 20:45
