Thread: Advice on car wiring... please
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Default Advice on car wiring... please
    I have a 12v cigarette lighter in the front column and one in the rear centre arm rest. The Rear one is 90% of the time in use with my Iphone etc and the front, say 30% is used for the satnav charger...
    I'm looking to fit a heated seat kit to the front seats (Not Factory kit) and it needs a 12v live and an earth point.
    Now, I'm not sure what sort of draw the wiring for the cigarette loom can take and I'm guessing the front and rear ones follow the same loom. The wiring looks sturdy enough, but worse case with all 4 items on and drawing 12v down the same wire, how is it likely to hold up?
    Thanks in advance!
    Jan 2012
    Milton keynes
    Mileage : 38100
    Also, wheres a good earth in the glove box / cigarette lighter area?
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    I think for that I would definitely run a fused 2.5mm live direct from the battery. Theres a grommet behind the glove box to allow you access through the bulkhead. Id just run an earth to the battery at the same time.
    Dec 2011
    Seaham
    I agree with the above, the cigarette lighter will not provide sufficient current. Run an independant wire fomr the battery with a suitable fuse. Use a relay to make it live only when the ignition is on, otherwise you could flatten the battery.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Mate the draw on heated seat elements will be too much.
    run a fused wire in yourself. And plenty of earth points around dash area.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Holy smokes batman that's a loom heading for meltdown. The voltage isn't your issue bud it's current draw and your original plan is a recipe for a car fire that's a lot of current in a thin wire equals plenty of heat. Best advice as above or fit after market pads and use the existing Vectra wiring if you have it.
    Jan 2012
    Milton keynes
    Mileage : 38100
    Okay... so I get the idea that the general consensus is not to use the Cigarette lighter live LOL. Thanks for the replies so far!
    So, next question, this is the kit I have... http://www.ebay.co.uk/itm/WAECO-HEAT...item564d94c4fa
    It comes with a relay and fuse already in the wiring loom, but I need to find a way of making the wiring live only when the ignition is on. Any ideas?
    Jan 2012
    Milton keynes
    Mileage : 38100
    Evening Bumpity bump
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    use something like ciggeratte lighter feed to power the relay.
    Do you have the kit their already?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Online instruction manual here
    http://www.waeco.co.uk/docs/Ins_msh-50_eb_10s_02.pdf
    Looks like a lot of work to fit the seat pads.
    The current draw is 8 amps max. It does need a perminent live feed from the battery and also needs a live with ignition that can be taken from the cig lighter, but the wiring and relay are provided.
  1. Advice on parrot wiring loom please :-)
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2012, 20:42
  2. battery and wiring advice
    By mungo1985 in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2012, 18:54
  3. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  4. Denison Icelink - wiring advice please?
    By MCD in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2009, 17:56
  5. Car Kit - Wiring Advice CD70
    By DesignforLife in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2007, 18:51
