Results 1 to 10 of 16
Thread: Winscreen washer pump
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default Winscreen washer pump
    The washer doesnt seem to have enough energy to pump the water properly at the moment.
    I have taken the pump out and cleaned it all up.
    The weird thing is, if I slot the pump back in at an angle, it pumps fine.....and more weirder - if I swap the front with the back it pumps fine too, just the wrong way round.
    But even with it slotted in normally, it pumps to the back fine, just the front is weak!
    Is it just a new pump needed?
    WEIRD!!
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Could be a blockage some where
    Birmingham
    Thats what I thought, but when I reverse the two, as in connect the back in place of the front and vice versa, it pumps fine!!
    11 Post(s)
    Have you also cleaned the filter that the washer pump fits into?
    http://www.vectra-c.com/forum/showth...eenwash-filter
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Sure I have one in my box of spares in the attic.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    did you pull the filter out of the tank? little black gromet looking thing that the washer pump sits in?
    Birmingham
    No, didnt think I needed as it worked the other way round for some reason. Will have a play again on the weekend!
    Are you VXR Enough
    13 Post(s)
    the filter will be gunged up fella
    11 Post(s)
    Quote Originally Posted by Vaux-Man-G View Post
    Quite possibly only one side of the filter is gunged up with slimey screen wash. There is a mesh on either side of the filter, as well as at the bottom, hence why might be working when you put it in at an angle or swap the pipes around.
    Oct 2012
    West London
    Engine : 3200
    Mileage : 52000
    probably worth taking the pump and filter out and jetting the washer bottle out, I was amazed by how much sludgey gunge came out of mine (all washers work good as new now)
  1. Washer/pump/dohh!
    By nikroc in forum The 'Off Topic' room
    Last Post: 18th January 2011, 20:03
  2. Washer Pump
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2008, 13:29
  3. washer pump
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2008, 15:37
  4. screen washer pump
    By simon1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2008, 16:40
