Results 1 to 10 of 14
Thread: Bonnet wont open on 1.9 CDTI facelift
    Oct 2012
    Northampton
    Default Bonnet wont open on 1.9 CDTI facelift
    Hi Guys,
    Have a problem with my bonnet not opening, the car is a 55 vectra 1.9 cdti facelift model.
    I have read the various threads but still not able to get it open. Tried pulling on the metal round bit on the release cable with pliers whilst someone pushes and pulls on the bonnet but no luck. The front grill has no holes to try and poke anything through to pull on the latch.
    Thought of taking the bumper off but dont think it will without opening the bonnet. Not sure if the only way is to have a go from under the car by removing the under tray or break the front grill.
    Anyone have any ideas please? Thanks
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Aug 2012
    can you feel the bonnet catch being operated through the cable or does it feel like it may have snapped or come off. or does it feel like the cable is stretching without the nice click that signals the bonnet has released?
    Oct 2012
    Northampton
    have tried pushing/pulling on the bonnet whilst the cable is pulled from inside the car. When pulling on the cable is wont budge at all but when shaking the cable I can hear the cable move around at the bonnet end so not sure if this means it has snapped.
    Aug 2012
    does it feel loose then? or tight when pulled with no pop and loose' ish when pushed. If it the latter I would put some serious weight on the front of the bonnet over the catch. Like get someone heavy to sit on it while you pull the latch.
    Oct 2012
    Northampton
    the cable is tight when pulled and nothing happens, we tried to push the bonnet down with full force whilst pulling on the cable but had no luck.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Thought u could unlock from lifting car up and unlock manually from under car? Might apply to vectra,
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    this happened on my old astra twice, first time I was able to disconnect the cable from the pull lever in the drivers foot well and pulled on it with a pair of pliers. Its at this point I should of replaced the cable, second time I had to smash the grill out and release the latch with my hand, cost me a cable and grill then!
    Oct 2012
    Northampton
    the plan tomorrow will be to get under the car, remove the under tray and have a go from here. Need to get this sorted cos MOT expires on Friday.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Before you start taking things off try this it worked for me took about 10 mins of fiddling and swearing but it does work
    http://www.vectra-c.com/forum/showth...t=stuck+bonnet
  1. Bonnet wont open
    By hairymark in forum Bodywork & Interior
    Last Post: 20th December 2012, 03:10
  2. Help!bonnet wont open!
    By dazza2393 in forum Bodywork & Interior
    Last Post: 2nd January 2012, 15:28
  3. Bonnet wont open
    By boodoo warrior in forum Bodywork & Interior
    Last Post: 14th August 2011, 14:55
  4. Bonnet wont open
    By Apone in forum Bodywork & Interior
    Last Post: 17th September 2009, 00:03
  5. Bonnet wont open
    By Johnytuono in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2006, 13:30
vauxhall vectra bonnet release problem
vauxhall vectra bonnet release broken
2008 vectra bonnet catch cable broken how can i open bonnet
vauxhall vectra c broken bonnet cable
vectra c bonnet wont open
how to get bonnet up on vectra if catch doesnt work
how to get into the bonnet Vauxhall Vectra c
how to open vectra bonnet
how to get a bonnet open on a Vectra 1.9 CDTi
vectra bonnet cable broken
vectra facelift bonnet jammed
vectra bonnet wont open
vectra c bonnet stuck
vectra 2006 bonnet catch
how to open a vectra c bonnet
vauxhall vectra c bonnet not opening
vectra c facelift bonnet wont.open
Tags for this Thread
