Thread: 2007 Vectra Design 1.8 vvt electrics / engine cutting out
    Oct 2012
    Paisley
    Default 2007 Vectra Design 1.8 vvt electrics / engine cutting out
    HI,
    My Vectra is cutting out at random times. The engine shuts down and all the dash controls fail and the headlights turn themselves off. Power steering goes also.
    Is this likely to be the dreaded CIM or can anyone make another suggestion ?
    John
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Starting with the basics, have you inspected the battery terminals and had a good look around under the bonnet.
    It could also be a loose earth wire, there are lots of earthing points under the bonnet.
    It sounds more widespread that just the CIM.
    Oct 2012
    Paisley
    thanks,
    Earth cable could be a good shout, I noticed the lights dimming before the entire thing cut out. Battery terminals were all tight.
    Odd that the dash lights remained on.
    The car has sat for 4 to 6 weeks.
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Assuming that the lights go bright when the car is reved up, and this fault only occurs when you have driven it, then I would suspect the battery has a problem.
    If it is over 3 years old then replacing it might be a good idea. Fit the biggest capacity battery you can afford and fit in the space.
  1. Vectra estate 3.0 V6 SRi, diesel. 2007. Cutting out/not starting! ...
    By Katie in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2013, 16:49
  2. Lights and other electrics cutting out when car is reved
    By daftladd in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2012, 19:12
  3. Dull lights - 2007 Vectra Design
    By jbrines in forum Vectra C / Signum Troubleshooting
    Last Post: 17th March 2011, 14:11
  4. Vectra C - 2002 - Electrics Cutting Out.
    By Nicko_12345 in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2010, 17:43
vectra c 1.8 cutting out
