Results 1 to 10 of 23
Thread: clunking
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default clunking
    had a clunking from the front end of my preface vec for a while, its an auto box. when i pull away it clunks, then if i stop and go in forward or reverse, it clunks, sometimes a double clunk. ive tried full lock and reversing, no noise or grinding. sounds like someone banging the floor under my feet with a rubber hammer. drivers side inner cv boot was changed just before i got it, looks fine, as do the other boots, but googling it really sounds like a cv joint. checked drop links, look good, the other bushes look ok too, inc engine mounts, tried lubing them, no difference. its worse if its cold. i have also noticed its got a bit of a wobble now with the front wheels, this wasnt there a month ago, feels like tracking or wheel balance but havent hit anything so should be ok. its a 2.2dti sri auto on an 04 plate. is it a lot to change the cv joints, also checked the front springs, all ok, and top mounts seem good, turned wheel jacked up, no swaying about.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    sounds like radiator mounts bushes
    http://www.vectra-c.com/forum/showth...adiator+mounts
    post 6
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    when you say wheel wobble do you mean on the steering wheel
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    thats more of a creaking noise, mines a clunk, if i slow down but doent stop, no noise, but if i stop at lights, then pull off again, clunk clunk
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    the steering is wobbling a bit, hence why it seems like front wheel wobble to, like when tracking is out, and only 60 +
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    Quote Originally Posted by andy_richmond View Post
    wheel balance sorted mine out
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    have you sprayed wd40 on the radiator mounts?
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    i sprayed everything i could get to at the weekend, all bushes, eng mounts even where the springs sit, and the rad mounts, well, from what i could see of them, whats the best way, from engine side of can you get to them from the front under the little rubber flaps, pics could be helpful to see if i sprayed the right bits
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    this was off another thread on here
    I opened the bonnet this morning, located the two springs at the top of the radiator at either side, sprayed with WD40 and hey presto, as soon as I reversed off the drive the problem was gone so thanks very much - I am now a happy bunny that's not being driven mad by an annoying creaking noice when travelling at low speeds.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    seen that one, thats creaking, i dont have a creak, its a definate clunk, like a rubber hammer, you can feel it with your feet
  1. Rumble and clunking
    By Gazza36 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th July 2012, 20:28
  2. clunking noise
    By keggy77 in forum Engine & Drivetrain
    Last Post: 6th January 2012, 16:07
  3. Clunking sound
    By snowball1 in forum Suspension, Wheels & Brakes
    Last Post: 4th September 2009, 01:13
  4. Vec-B Help please, clunking noise or something!!
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 19th August 2009, 10:44
  5. clunking noise
    By mark the hat in forum Suspension, Wheels & Brakes
    Last Post: 20th March 2009, 21:02
https:www.vectra-c.comforumshowthread.php174765-clunking
