Thread: Bad smell cure
    Nov 2010
    East Midlands
    Trim : design
    Default Bad smell cure
    My lad called round at the weekend in his Astra complaining of a 'bad egg' smell coming from the engine compartment into the cabin - he thought it was something to do with the catalytic converter being faulty. Had a drive around in it and sure enough it stunk to high heaven - although it was definitely coming from the front of the car as opposed to the rear where you would expect it if it was the cat. Had a good look around the car and eventually found it was coming from the screenwash reservoir bottle. Flushed it out by pushing a hosepipe down inside the bottle and allowing to run for half an hour - then emptied the bottle by pumping it through with the washer lever. repeated this and then filled the bottle with neat windscreen washer concentrate ( courtesy of EPC's recent offer) and smell now gone. Worth bearing in mind if you get a bad smell !
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    yuk lol
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    yolk okey dokey
    Dec 2011
    Seaham
    When my mate got married we doctored his car with kippers!
    He found the obvious ones under the seats, on the manifold on the radiator. But never found the one ontop of the middle exhaust box..... Phew!!!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Had the same thing on my washer bottle back in the summer , totally removed the washer bottle and flushed it out with anti bacterial spray from household cleaner partially refilled bottle with antibacterial cleaner to clean pipes then topped up with scented screen wash has been ok ever since
    and still loving it
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    sounds to me as if someones dropped a egg in the screenwash reservoir bottle
    my halfords screenwash smells loverly lol
    May 2012
    northumberland
    i wonder if there is anything that be added to the screen wash, to bring a scent in through the air vents when using the wash fluid?
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by 06sri View Post
    I'll send you some of my Old Spice
  1. What is your hangover cure?
    By mattv6diesel in forum General Chat
    Last Post: 20th June 2013, 20:27
  2. My flat spot cure
    By neill in forum Engine & Drivetrain
    Last Post: 25th March 2012, 21:44
  3. Has anyone found a cure for.......
    By John LE in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 12:53
  4. Anyone know a cure for
    By mc_orion in forum The 'Off Topic' room
    Last Post: 21st October 2008, 13:32
  5. Hangover cure
    By mark1319 in forum Quick Photo Album
    Last Post: 18th April 2008, 19:22
bad smell coming from inside Vauxhall Vectra
