Thread: signum heater resister
    Regular Member neil52's Avatar
    Oct 2012
    leeds
    Default signum heater resister
    replaced heater resister cleaned scuttle tray and all working fine went for a drive sunday terrible smell of burning and smoke coming from passenger footwell only when heater on 1 2 3. 4 was fine, now im back to square 1 heater is only working on 4 again ive ordered the resister again. any ideas what could cause this before i fit the new part.
    Dec 2011
    Seaham
    Where did you get the resistor from? It could have been faulty or the wrong resistor?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    Quote Originally Posted by neil52 View Post
    ive had this before what normally happens is where the water has come through the pollen filter into the heater blower this takes the grease out of the blower and normally squeaks
    then the bearings start to dry putting more pressure on the blower and the resistor pack gets very hot causing the fuse to go again
    which is why i only have mine on for a few seconds or mine will go again
    the only fix is to take out the blower and get the water or rust out caused by the scuttle leak
    or buy a new blower
    there are a few threads on here regarding cleaning the blower
    this is a common vectra c fault
    this is why i started this poll post 182 and 183
    http://www.vectra-c.com/forum/showth...l+scuttle+tray
    Oct 2012
    leeds
    from ebay
    Oct 2012
    leeds
    well ive fitted the new heater resister and took blower motor out cleaned and replaced and so far all seems ok. But i think i caused my own fault were you slide the heater resister i dont think i fitted it right as it had come out and the burning smell and smoke was caused by the resister touching the carpet i have told myself off.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    My eBay resistor was the same. Where it slides in was slightly different. Had to "modify" it slightly for it to fit right. No issues with it though
    May 2006
    scotland
    My ebay resistor pack stunk to high heaven as well as needing plastic cut out to get it to fit. Then the thermal fuze blew (it was of a lower temp rating than OEM one). I ended up fitting a correctly rated thermal fuze to the original OEM pack and re-fitting this to the car. No smell and has been working for months now.
  1. signum heater resister
    By neil52 in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2012, 19:58
  2. heater resister were from?
    Last Post: 8th March 2011, 14:35
  3. No Heater in my signum
    By malcwit in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2010, 23:09
  4. Is the a way 2 test heater resister on a vetra
    By eddie lane in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2009, 19:08
smoke from passenger footwell vectra c
