Thread: Service time
    Regular Member Beardy's Avatar
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    Default Service time
    Hi peeps, I'm gonna be doing a full service on my 2.0 T Signum tomorrow, any things i should be wary of? Never worked on this engine so mot sure if anything is abit iffy to get to or undo? Any help and hints would be much appreciated.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Everything's very easy to get to on the 2.0T, you'll need a 32mm socket to get the oil filter casing cap off, sump drain plug is usually a 15mm socket but some have torx bolts in them. Four torx bolts to get the engine cover off, 10mm socket to remove each coil pack and standard spark plug socket to remove the spark plugs. Air filter is the same on pretty much all Vectra's, a few torx bolts to undo on the cover until they're spinning (don't need to fully remove them) and the cover pivots sideways on it's hinges (you'll need to use a 7mm socket on the jubilee clip to undo the MAF first.
    Fuel filter is under the drivers side just infront of the rear wheel, two clips to remove (they're fiddly if you don't have the right tool and best to get replacement clips when you buy the filter too).
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    Thanks mate I've done the majority of it now but got a rounded off torx screw on my air box i canne undo. Also i was told and got 6 litres of 5w 30 fully synthetic GM oil, as told to change it every 30,000 miles or 3 years, is this right? Always done it every year on all my other cars.
    Quote Originally Posted by Beardy View Post
    The diesels (same MY) are 30K miles / 2 years
    The petrols are 20K miles / 2 years
    The Service Indicator on your car should show you how many miles left to next service
    On completion of service, reset this
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    i wouldnt be leaving the oil in for 3 years /30000 no matter what anyone told me, and 5l is enough well it is on my 2.2 direct and leaves a little over for a top up when needed, think your engine takes same amount of oil as mine.
    South east
    The Z20NET has a capacity of 6 litres, but half a litre will stay in the engine when you drain the oil, so you'll need 5.5 litres of new oil to make the oil level reach the MAX marker on the dipstick.
    Quote Originally Posted by 06sri View Post
    It's 30K miles / 2 years, not 3 years
    Discussed before, I had my doubts about this, especially in a diesel
    However, it is a service indictor and limit
    Mine has never reached the 30K miles and the interval reduces dramatically around 15K miles, such that the service was performed nearer to 22K miles
  1. time for a service
    By danno91 in forum Engine & Drivetrain
    Last Post: 10th October 2011, 21:56
  2. Service time...
    By Billy110 in forum Diesel Engine related
    Last Post: 5th October 2011, 17:40
  3. Time for a service or not ?????
    By nelly452 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th September 2011, 23:23
  4. Service and MOT time
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 13:00
  5. Service time
    By andyxedos in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2010, 21:05
