Results 1 to 10 of 18
Thread: help!!! 1.9cdti 120
    May 2012
    St ives
    Default help!!! 1.9cdti 120
    After having my engine rebuilt after cam belt went had to take the car back in today to have all the fluids drained and 're filled and have a new thermostat fitted. Driving home noticed absolutely no power loads of smoke and loud hissing noise.
    Pulled over and opened bonnet to see a large hose on the passenger side over the thermostat next to the battery was off and they hadn't put a jubilee clip back on.
    1- what is this pipe
    2-what damage has those caused
    3-is it just a case of putting it back on with a jubilee clip.
    4-is there anything else I should look out for and check.
    Hope you guys can help me asap. This car has cost me far too much so far with engine rebuild new starter motor and thermostat.
    Thanks in advance
    Alex
    Aug 2012
    sounds like the turbo outlet to inlet manifold hose. Not a big deal just clamp it back on and all will be well. This hose coming off would cause the symptoms you describe too. No need to worry I think. Although I may be telling the garage that you want £100 to cover the cost of having it towed because at the time you thought it may be serious and not their mistake! LOL
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    Quote Originally Posted by jamesmcuk View Post
    agreed!
    james did you get your new turbo fitted?
    Aug 2012
    Thursday mate! Cant wait! :-)
    Jun 2012
    lancashire
    you will be disappointed you cant give it some till its bedded in some say 200 miles my garage said 500 all minimum boost
    Aug 2012
    Well the guy who supplied mine didn't say anything about that you know. And IMO its been balanced in the same bearings its still going to be in, in the same housings it will be in and at full boost. In fact the only difference will be that it will be using good old Lancashire Air instead of Scottish LOL. With this in mind I can't see I need too "bed" it in. What do you think?
    Jun 2012
    lancashire
    if its second hand then fine if its a recon one then you need to bed it in
    Aug 2012
    Quote Originally Posted by john norris View Post
    Its a recon so maybe I will then. What did they advise? Keep below 3000rpm or similar?
    May 2012
    St ives
    Here is the offending pipe/jubilee clip?
    Can anyone shed any more light on it? And provide anymore answers to my original post?
    Many thanks
    Alex
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Sharks35 View Post
    Many thanks
    Alex
    Get two new strong jubilee clips. Make sure the pipe has no splits in it, and re-attach it very securely No damage would have been done when it popped off. Mine popped off at 70mph a couple of weeks ago. Pulled over and re-attached, then off I went
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. 1.9cdti sri 120
    By dsimpson15 in forum Introduce yourself.
    Last Post: 21st April 2012, 19:24
  3. 1.9CDTI 120 55 reg
    By rjw in forum Cars for sale
    Last Post: 15th March 2011, 15:28
  4. De-Cat 1.9CDTI
    By gregc in forum Diesel Engine related
    Last Post: 26th January 2009, 10:33
