Results 1 to 3 of 3
Thread: Probability of damaged liners
    Oct 2012
    peterlee
    Default Probability of damaged liners
    Hi im pretty sure that the head gasket on my z19dt is failing . The cooling system is pressurising and coolant drops then when pressure releases coolant is blowing out of the back of the header.
    The car doesnt overheat according to temp gauge ! Water pump has been changed coolant system flushed, thermostat changed , header and pressure cap changed .
    My question is what is the probability of the liners having dropped ?
    Regular Member gixerjd's Avatar
    Dec 2011
    leeds
    Vehicle : vectra c
    Trim : vxr
    Engine : z28neh
    Mileage : 31000
    do a compression test fella should tell you if anything is wrong
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    May find it's blowing steam out of the exhaust, if diesels have head gasket like petrol.
  1. Italian Cruise Liners
    By davidj241 in forum Comedy & Humour
    Last Post: 3rd February 2012, 23:18
  2. Boot Liners
    By NAYLAD in forum Detailing and Car Care Discussion
    Last Post: 30th September 2009, 23:13
  3. Cylinder liners for V6 CDTi
    By Celes in forum Engine & Drivetrain
    Last Post: 24th September 2009, 15:04
  4. Probability....... 0.00000001%
    By spoons in forum Comedy & Humour
    Last Post: 6th March 2008, 14:32
