Thread: Anyone know what this plug is for?
    Oct 2006
    Yorkshire
    Default Anyone know what this plug is for?
    Hi guys
    Have removed my CDR2005 VDO siemens Head Unit from my Veccy and this is the plug that came out of the back of the stereo.
    The middle plug and the right hand side one are clearly the ISO connectors but does anyone know what the one on the left is for? They are all moulded together as one single plug but cannot work out what this plug is for at all.
    Satnav????????? and poss aux feeds for phone etc???....
    Where's Ben H when you need him.....
    Hertfordshire
    That will contain the non standard audio connections, like the speed pulse, dash display and steering wheel controls etc, stuff like that.
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    yes it looks like a variation on this quad lock plug:
    for which this is the pin layout diagram: (piccies nicked from here: http://forum.vectra-c.com/showthread.php?t=16844&page=6)
    Regular Member benny's Avatar
    Feb 2006
    dudley
    its used for the radio display so you know what channel you are on and so on also gives the clock the rds signal .......
    Regular Member jimbob's Avatar
    Apr 2006
    swansea
    Looks like the old stereo/display connectors from a Veccy b.
    Similar to this.
    Top two being stereo leads, bottom is display connector.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by Green Growler View Post
    Spot on. You can split the block off if you want to fit a parrot kit then you dont have to get the extra lead. If thats what your up to give us a shout, ive done it to my 2005 vdo HU.
    Oct 2006
    Yorkshire
    Hi Rushy,
    How did you split the block off? The only way I can see doing this is to to actually cut the plastic that joins the blocks toegther?
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by bennyk View Post
    Hi Rushy,
    Yep thats what you have to do. The only down side in taking this short cut is the iso block needs a little bit of persuasion to get it back into the HU. If you connect the kit up and the power of the phone kit flashes then thats the canbus kicking in. Its very easy to get round, so if you get stuck give us a shout.
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. preface gid screen plug, is it the same as the 32 pin vec b mid plug?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 23:15
  3. plug
    By titley1976 in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2011, 22:14
  4. blue plug display into a grey plug vehicle
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 23:09
  5. grey plug yellow plug?
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2010, 14:35
