Results 1 to 10 of 20
Thread: thermostat or waterpump help please
    May 2012
    wirral
    Default thermostat or waterpump help please
    people i need advice please , ive got no heat coming from cabin , the temp gauge is reading 95-100 degrees , ive lost no coolant and the car is running fine with no noises or lights on dash coming on , the fans are kicking in but not cooling it down if i stop it cools down on idle but as soon as start driving again it rises up to 100 degrees rapidly.no matter what im getting no heat coming out in the cabin just stone cold air even at 100 degrees..
    am i looking at water pump failure or thermostat?
    its killing me this car last month was alternator and two tyres on 19" snowflakes , bank balance is getting a good hurting .
    cheers
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Water pump mate
    I'd also replace the thermostat while you're at it, if its not been done yet
    ---Sent from my iPhone 4 using Forum Runner
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It sounds like the pump have you tried gently unscrewing the expansion tank when it's hot to see if there's any pressure in the system do it carefully though and slowly. If it is the pump don't drive it you will knacker the engine. It might just be the thermostat though and is stuck closed and thermostats on the Vectra fail quite a bit however the common failure is stuck open so as it never heats up. Change the stat first as it is easier and cheaper.
    Dec 2011
    Seaham
    Could just be the thermostat stuck, take it out and change it. You can check to see if you have flow from the waterpump by taking off the return pipe and starting the car, water should come out.
    May 2012
    wirral
    thanks for replies ill take return pipe off today and see what happens , i presume if water comes out then water pump is working fine still ? and ill be looking at thermostat?
    Dec 2011
    Seaham
    Yep, the waterpump will still pump the water around the enine util its hot enough to open the thermostat and direct the water through the radiator.
    My thermostat seems to be stuck open, so need to change it.
    23 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    You'll be able to see the water coming out yes if the pump is working as it will be pushing it around the system. Thermostats fro the Vectra normally come with the housing at about £40 ish.
    May 2012
    wirral
    thanks again fully appreciate it
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 128000
    my guess is the water pump is seizing be careful you do dont break the cambelt
    or do the head in
    in this thread below the water pump seized at 55000 miles
    click below
    http://www.vectra-c.com/forum/showth...6v-CDTi-owners
    Admin plasma's Avatar
    On the Forum
    219 Post(s)
    Engine : 150
    Mileage : 74000
    if it was the thermostat you'd still be getting hot water through the heater matrix and into the cabin ... So my bet is on the pump or a blockage as well.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. 1.8 Waterpump
    By Tinks in forum Engine & Drivetrain
    Last Post: 10th January 2013, 23:29
  2. cambelt kit and waterpump
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 19th June 2012, 20:30
  3. Cambelt and waterpump
    By Innocence in forum Engine & Drivetrain
    Last Post: 26th September 2011, 17:13
  4. Waterpump
    By Tam80 in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 20:14
  5. waterpump
    By barry0101 in forum Engine & Drivetrain
    Last Post: 21st January 2010, 09:42
