Thread: adhesive for sticking carbon fibre vynil
    Aug 2012
    basingstoke
    Default adhesive for sticking carbon fibre vynil
    Ive just carbon wrapped my silver tailgate trim and it looks excellent but i dont really trust the glue thats on the back so ive decided to glue the back of the trim to lock it in.
    Can anybody suggest a good weather proof adhesive that will keep the stuff stuck down
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    My vinyl has been on for about 14/15 months and had no problems what so ever
    newport
    as a self employed signwriter or 'car sticker maker' as my youngest calls me lol, i would say there is no need for any extra adhesive, if fitted correctly it should be good for at least 2 years if its the stuff i think it is, and if and when it goes, there is no lasting damage and can be returned to normal or redone for next to no expense, if you do apply extra adhesive, it may ruin the part being applied to
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    As above! Especially if you stretch it or heat it so it shrinks round the object. No need for extra adhesive whatsoever
    Aug 2012
    basingstoke
    Thanks guys
    The stuff i got was off amazon,its not 3m so am a bit worried it could unpeel espcially around the corners as i had to stretch and tuck it.I dont mind about spoiling the part as i have a spare one if it doesnt work out
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    if you want the best thing you could do is seal the edges with clear lacquer and a small brush to stop any water penetrating as with pin striping if its a good quality vinyl the glue should be 5-7 year
    Jun 2012
    lancashire
    also cast vinyl has memory of being a flat sheet heating it up after applying wipes that memory and causes it to remember its current shape thus removing tension on the adhesive
    Aug 2012
    basingstoke
    Thanks again guys.
    Ive got some clear lacquer so will put some around the edges.
    john norris is correct,the stuff ive got unsticks and straightens out when i heated it up.Im gonna give this stuff a try for the moment and in the meen time im gonna get some good quailty stuff and do the spare strip ive got and see how it goes.
    Jun 2012
    lancashire
    i use the stuff everyday for the past 14 years id hope so :]
  1. Replies: 8
    Last Post: 20th August 2012, 08:09
  2. self adhesive carbon fibre
    By keith1983 in forum Styling
    Last Post: 11th December 2009, 15:32
  3. Would anybody like Carbon Fibre?
    By VectraMat in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2009, 20:30
  4. carbon fibre
    By dominic32 in forum Styling
    Last Post: 21st June 2009, 12:05
  5. Carbon Fibre has its uses... but...
    By spoons in forum General Chat
    Last Post: 13th September 2007, 14:22
