Results 1 to 10 of 18
Thread: thermostat fail
    Oct 2012
    liverpool
    Default thermostat fail
    hi guys i think my thermostat has failed in car as the temp just never reaches 75 an when on a long run it wont show on gauge at all but question i want to ask is if its failed is there bad fuel consumption an loss of power? it seems sometimes when i start car it will have a tank range say 50 miles. i will do 2 mile journey but then me tank range has dropped to like 40. does this happen with all the vectras or could it be the thermostat needs replacing
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    yes this happened to me you need a new thermostat and yes you will be using more fuel
    common fault on the vectra c
    yours is diesel and the temperture gauge should read 86-90 degress and stay there
    there are plenty of threads on this site regarding thermostat failure
    just type thermostat into the search part
    Oct 2012
    liverpool
    thanks mate just hope i noticed improvement in mpg. i will do more searches an see what problems people have had
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    Quote Originally Posted by seddo View Post
    theres no loss in power its just you will use more fuel as the cold weather comes
    click below
    http://www.vectra-c.com/forum/showth...ature-Question
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    replaced my thermostat at 53000 miles
    i have the 1.8 it takes around 3 miles to get to 86-90
    say with the outside temperature at 11 degress
    sometimes it goes to 92 and when the fan cuts in it goes back to 86-90
    if it is reading between 70-75 after 20 minutes its broke
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    the classic sign of a faulty temperature gauge is
    it sits at 0 for ages, moves up to 80 then drops back to 0 again
    Oct 2012
    liverpool
    Exactly what my symtoms I've got. Do you know if a new gasket is needed?
    Dec 2011
    Seaham
    Why do the thermostats for the 1.8VVt's come with the housing and 2 sensors, you only need the thermostat and a gasket??
    I might see if I can take the thermostat out of the housing and get it matched? Its probably the same as a standard 1.8/???
    Oct 2012
    liverpool
    Does anybody know if u need a new gasket with the housing or is the rubber seal good enough?
    May 2012
    St ives
    There's a sticky somewhere about a thermostat that superceeds the original. I bought it off the bay and had it fitted and now works a dream
  1. Would any of them fail MOT??
    By signum04 in forum Suspension, Wheels & Brakes
    Last Post: 14th May 2012, 19:11
  2. MOT fail, Co2
    By GCusdin in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2011, 10:06
  3. HID fail
    By alijlacy in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2011, 11:07
  4. Is it an MOT fail?
    By Lee_gsi in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2010, 11:53
  5. Mot Fail
    By Cam in forum Engine & Drivetrain
    Last Post: 8th February 2010, 23:11
