Results 1 to 10 of 25
Thread: Another day and another fault! .....
    Regular Member Marvec's Avatar
    Oct 2012
    preston
    Default Another day and another fault! .....
    Recently my car has decided to mis - fire and go into limp home mode, with the spanner light coming on briefly and the engine light staying on, its starting to get worse now so i have plugged my scanner in and the following code comes on...
    P0353 Ignition coil c Primary/secondary circuit.
    Im thinking i need a new coil pack? and is it wise to do the spark plugs too?, as they havnt been changed for a while, thanks .
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Plugs an coil pack mate yeah.
    What diagnostic are you using? Is it bi directional ( can you do actuator testing)
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    id do the plugs as well they are cheap about 2 pounds each
    try that first but i think your find its the coilpack mate
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    on the 1.8 the spark plugs should get changed around 80000 miles
    i changed mine at 60000 miles
    Oct 2012
    preston
    cheers for all the advice, i will be changing the coil pack and plugs and hopefully it works .
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Quote Originally Posted by Marvec View Post
    keep us upto date
    Oct 2012
    preston
    Quote Originally Posted by vectra ste View Post
    keep us upto date
    will do, going to have a ring around for parts tomorrow.
    Oct 2012
    preston
    Quote Originally Posted by Critch View Post
    Im using a Quicklynks T55 e, good all rounder, this model is designed for skoda/vw/audi it has OBD11/ EOBD + CAN which works with vauxhall, here is a screen shot of my new fault... .
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Not bad but if ya stuck give me a shout fella ya local to me and I have tech 2
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    One other thing who's thumb is that looks like a faulse nail or gel ones fpmsl
  1. Not sure if this a fault or not.............
    By carperjake in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 20:39
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. ABS fault...
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2011, 03:05
  4. Another Fault
    By khile in forum Vectra C / Signum Troubleshooting
    Last Post: 20th March 2010, 18:57
  5. swirl valve fault or egr valve fault
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 09:04
