Thread: Is it the temp sensor or thermostat 1.9cdti
    Regular Member bennettboy's Avatar
    Havant UK
    Default Is it the temp sensor or thermostat 1.9cdti
    Hi all,
    Picked up my 55plate 1.9cdti 120 on Friday, whilst on the test drive noticed the temp gauge not working. Dealer changed temp sensor and hey presto gauge working all be it slightly erratically.
    Saturday morning put key in and switched on ignition and noticed the temp gauge move up to 60 degrees or so despite the engine being stone cold, tried starting car and it wasn't having non of it (outside temp 2degrees) eventually it fired up and ran fine. Temp gauge hardly moved.
    Bought another sensor popped it in and again the gauge didn't move at all on the journey home, but had heat in the car. So popped the sensor that was working back in and the gauge moved again all be it no higher than 85 degrees.
    So I'm slightly confused as to why two sensors didn't work one does all be it erratically ie: showing temp on cold engine. Could it the thermostat causing the issues??
    Any help or suggestions gratefully received.
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    sorry to hijack your thread but is this the temp sensor?
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Z19DT ?
    Here (B39) :
    Aug 2009
    Trim : elite
    excellent cheers z80
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Quote Originally Posted by bennettboy View Post
    Hi all,
    Id suggest put back the new sensor that you bought then change thermostat
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by troutybrown View Post
    New thermostat comes with the sensor
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    its very common on the vectra c that the thermostat breaks
    (the gauge stays around 86 degress and stays there this is with a new thermostat fitted)
    unless you put heater 4 setting on on it drops
    if it goes to 70-75 with the heater( off )its broke
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    make sure you fit a original gm thermostat in
  1. Thermostat or temp sensor
    By vectra-man in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2013, 08:07
  2. Z19DT Exhaust Temp Sensor Help... & Thermostat...
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 26th June 2012, 22:08
  3. Thermostat or temp gauge or nothing?
    By mrpoochie01 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th March 2012, 12:11
  4. thermostat & temp sensor
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 16th December 2011, 12:37
  5. cant unplug my temp sensor on my thermostat
    By justin32 in forum Engine & Drivetrain
    Last Post: 10th December 2011, 16:16
https:www.vectra-c.comforumshowthread.php174612-Is-it-the-temp-sensor-or-thermostat-1-9cdti
vectra 1.9 cdti temperature gauge not working
vectra temperature gauge not working
vauxhall vectra 05 1.9cdti temperature fault
vauxhall vectra 1.9 ctdi engine temperature gauge varies
vectra c temperature sensor location
vauxhall vectra 1.9 cdti temperature gauge not working
vectra cdti temp gauge not working
vectra cdti 06 no temp
vauxhall vectra 1.9 cdti thermostat problems
cdti temperature
vauxhall vectra 1.9 ctdi engine temp gauge varies a lot
vectra 1.9 cdti 150 thermostat
where is the heat gauge switch is located on a opel astra
vauxhall vectra 1.9 cdti 150 temperature sensorvectra c 1.9 cdti disconect temp sensor 05 vectra cdti no temp gaugevauxhall vectra 1.9 cdti 150 thermostat sensorTermostat opel vectra c 1.92008 vauxhall vectra 1.9 cdti temperature gauge not workingfitting temp gauge to 1.9cdti zafira 1.9 06 thermostat problemsvectra c cdti temperature gauge not workingvectra cdti temphow to fix a temperature gauge work on my Vauxhall Vectra 1.9cdti
