Thread: 2.0DTI Lumpy & smokey in the morning, and drinking oil
    Maidstone, Kent
    Engine : 3.0 CDTI 184
    Default 2.0DTI Lumpy & smokey in the morning, and drinking oil
    Evening all,
    I need some advice, my 2003 2.0DTI (135k on the clock) is taking a while to start in the morning, it is very lumpy & chucks out quite a lot of smoke for a few seconds too.
    I serviced it a short time ago (all filters & oil), and I am wondering if having air in the fuel lines could be causing the lumpyness ? I made the mistake of just taking the filter out & chucking the new one in without topping it up with diesel because I was in a rush.
    The engine is fine after 20-25 seconds but it is very very lumpy initially, any advice is very appreciated ! Cheers !
    Jan 2012
    Gloucestershire
    I don't know anything specific to this engine, but if the problem began right after having changed the fuel filter, maybe something isn't sealed fully allowing air back into the system when left overnight? Does the car startup ok if warm and left for only a short time? If the problem is only since you've changed the filter, check everything you disconnected/connected and any seals you have disturbed.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    do you get a car spanner light for about 45 seconds after start up?
    If so change your glow plugs
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    no idea regarding the oil consumption , my 2003 dti is on 182k & doesn't use a drop of oil .
    mine wasn't giving a glow plug light on a morning so had to be re programmed at the dealer ( field remedy 1579 ) even since then the glow plugs don't stop on for very long , so i find it better to cycle the glow plugs 2 or 3 times & the car starts perfect .
    Merseyside
    Sounds like the glow plugs - my 150 Diesel was lumpy as a lumpy thing for a few seconds after starting and took a while to fire up. I changed to glow plugs to brand spanking new NGK plugs and it starts on the button every time and runs smooth as silk from stone cold.
  1. What you drinking at the moment?
    By Steven in forum The 'Off Topic' room
    Last Post: 3rd December 2012, 22:40
  2. Drinking petrol
    By itsonlymedave in forum Engine & Drivetrain
    Last Post: 2nd September 2012, 15:43
  3. drinking and driving
    By Johnsdutton in forum Comedy & Humour
    Last Post: 1st May 2012, 14:55
  4. 1.8 drinking issue...
    By danBoy in forum Engine & Drivetrain
    Last Post: 23rd July 2009, 18:14
  5. Anyone drinking?
    By BlueRob in forum General Chat
    Last Post: 26th December 2007, 17:10
