Thread: headlight adjusting any tips
    Regular Member vermiculus-daemon's Avatar
    Oct 2012
    Ascension Island S.A.O (round about the middle of nowhere)
    confused headlight adjusting any tips
    i have a 07 v6 cdti, i kno every1's complaining about headights not havin much 'reach' out front, but is there a way to adjust the level of the high/dipped beam if there isnt a level adjustment switch inside by the light switch.
    i bought the car with HIDs already fitted as the dipped beam, but is there like some bolt or screw that i can turn to raise them?
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    sounds like your car has factory fitted xenons if there is no range adjustment on the switch , you would probably be better off calling at a local MOT garage & asking them to check/adjust your lights , most will do this for a small fee & at least then you will know they are correct & unlikely to dazzle others .
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Yes there is an adjustment allen bolt. If you lift the bonnet and look on the top of your headlight near the slam pannel. Will be 2 allen bolts, 1 for sideways, 1 for up/down.
    Dont ask which is which cant remember, but think the inner 1 is for up/ down.
    Do a search on here for Duncan Mod. That will put you right!
    Glasgow
    If you have factory xenons and they are poor then something is wrong. Is the fault light on? I would get the allignment checked any mot station will be able to adjust for you.
    Oct 2012
    no theres no fault light or nothin on, but i will try those allen bolts, cheerz Graham
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    If they have never been adjusted they will be aimed low... It's only an mot fail if too high IIRC, I adjusted mine and went a lot higher then it was and it still passes mot so worth adjusting... There's a how 2 somewhere with which does which but I think the outer 1 does the height...
    Regular Member Wolfie01's Avatar
    Nov 2010
    Wolverhampton
    May 2012
    county durham
    Mileage : 145k
    Quote Originally Posted by leemarksmith View Post
    wrong , it is also a fail if they are too low , although there is quite a bit between the upper & lower limits .
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Quote Originally Posted by Wolfie01 View Post
    He can't try that, like he said in original post he has no adjustment on switch.
    I assume his are self levelling so needs to check that the self levelling mechanism is working properly.
  1. headlight beam adjusting on facelift
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2010, 10:04
  2. adjusting headlights
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2008, 20:29
  3. any tips on how to cut the rear valance to show my exhaust tips
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 18:58
  4. adjusting mirrors
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 00:09
  5. Adjusting the headlight beam
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2006, 13:09
how to adjust vectra c headlights www.vectra-c.com
