Thread: Dodgy DPF Removal
    Merseyside
    Default Dodgy DPF Removal
    Hi all,
    Finally discovered what the occasional heavy smoke is on acceleration and idling.
    The symptoms are as follows:
    The car starts to judder slightly at idle, as it used to do when the DPF was starting to regen.
    On acceleration there are massive clouds of thick smoke coming from the exhaust which carries on at idle. This stops when i turn the ignition off and restart it.
    The 'dealer' was supposed to have removed the DPF because it was faulty but it is clear to me after closer investigation that the ECU thinks it is still there and therefore pumps raw diesel into the exhaust, causing the thick horrid smoke.
    If I get a remap, will I be able to get an add on part that maps the DPF out of the ECU as its really really annoying now!!
    Andrew
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep mapp it out and remap at the same time fella it's easy to do
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You can remap the EGR out as well. You say that the dealer removed it, was it a VX dealer? The DPF should not be removed without it being mapped out. If it was done under warranty I would be going back to the dealer to get it sorted. Have they replaced the DPF with a straight pipe?
    Merseyside
    It wasnt a GM dealer. The car concerned is a Saab 9-3 150 TID. I think the internals of the DPF have been removed but it hasnt been mapped out properly as the ECU still thinks it is there and is chucking fuel into a hot exhaust which is creating a 'Red Arrows' style smoke trail!
    scottish region
    any lights on dash like flashing glow plug or anything
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Sound like they just knocked it out lol woops
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    Quote Originally Posted by signum_1.9 View Post
    stick the aero badges on it take it to your local Tesco car park and start charging the boy racers admission
    on another note take it back to dealers and tell them to sort there botch out before your exhaust gets blocked or masperformance.co.uk should be able to sort it
    Merseyside
    Quote Originally Posted by DAVIDD88 View Post
    No warning lights at all. With it being a Saab, the Computer goes through a full check when I turn the igntion on - says everything is OK.
    Quote Originally Posted by paulvectrac View Post
    Pretty sure the clown has just removed the internals and 'forgotten' to map it out - hence the smoke screen every few thousand miles!
  1. bit dodgy
    By sig num in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2010, 21:58
  2. dodgy MAF
    By craigbarlow18 in forum Engine & Drivetrain
    Last Post: 2nd October 2009, 08:29
  3. its gets even more dodgy!!!
    By big rich in forum General Chat
    Last Post: 21st August 2009, 19:18
  4. Dodgy Ref
    By AJA in forum Comedy & Humour
    Last Post: 11th February 2007, 04:51
  5. How dodgy are you?
    By Tim2100 in forum General Chat
    Last Post: 14th December 2005, 20:15
