Thread: Loss of clutch pedal pressure..help??????
    Feb 2011
    Oxon
    confused Loss of clutch pedal pressure..help??????
    Hi,
    I own a 2006 Vectra CDTi 150 Sri.
    I've had my dmf, csc and clutch replaced at Mr Clutch (I know, but they were the cheapest by far!) around 1500 miles ago.
    Since then I had trouble getting into 1st or reverse gears in the morning on start up. Its fine for the rest of the day once the car had been warmed up. I've taken it back to Mr C, who just scratch their heads and say its fine.
    A couple of weeks ago the clutch stuck to the carpet when going from 4th to 5th and again 5th to 6th. the biting point was way down to the floor and the rest of the pedal travel was just weak, as if there were no hydraulic pressure. Took it back to Mr C who said the only thing it could be was the master cylinder. Had that changed and it seemed ok, for a week.
    Now the pedal still has a good few inches of play before I feel any hydraulic pressure- much more than it used to. It goes into gear ok now when cold though. If I pump the pedal 10-20 times before driving off the pressure seems to come back a bit. Mr C have tried bleeding it twice and reckon its free of air. Also they say there's no signs of a leak at the csc so therefore can't be air in the system.
    They have replaced:
    Dual Mass Flywheel
    Concentric Slave Cylinder
    Clutch
    Master Cylinder.
    They told me that everything between engine and gearbox is new so therefore any problems are now probably the gearbox. I'm not convinced they really now what they are doing.
    I have brought it back to them at every predetermined mileage for the check up to keep the warranty valid.
    Any suggestions would be very much appreciated!!
    Many thanks.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Clamp hose see if pressure builds and hoholds if it dies suspect faulty csc
    just be ause its new does not mean it can't fail
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    once had a similar problem after fitting a clutch to a dti for someone , turns out that some slave cylinders are just naff .
    Feb 2011
    Oxon
    I see. So do you think I should go back and suggest they check it out? I'm guessing they'll be very reluctant to replace the CSC without absolute proof of a failed part?
    May 2012
    county durham
    Mileage : 145k
    I would be getting onto them , especially after they have chucked parts at it & it still isn't right .
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    its down to them to sort you out mate, stick to your guns, dont go in all blazing just yet, remember you went there witha fault and asked them to fix it, however your stillhaving problmes, and yes new parts can be faulty, rare but it happens.
    you could be looking at the possibility of a full strip down again.
    Feb 2011
    Oxon
    Is there a possibility that there is air in the system as it seems to improve when the pedal is pumped? Or would this also be the case if the CSC is iffy? I read somewhere that there is a bit of a knack to bleeding vectra clutches........or am I clutching at straws? (Boom-boom)
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch pedal
    By BigWilko in forum Engine & Drivetrain
    Last Post: 9th January 2011, 08:38
  3. Brake pedal pressure
    By Karl12347 in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2010, 16:28
  4. clutch pedal
    By Tam80 in forum Engine & Drivetrain
    Last Post: 2nd September 2010, 19:41
  5. Clutch Pedal!!
    By andd306 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 21:48
vectra clutch pedal pressure
