Thread: CD30 To CD40
    Barrow In Furness, Cumbria
    Default CD30 To CD40
    What do I need to replace the CD30 in my 2008 Vectra to a CD40?
    I'm guessing CD40 unit and screen. If I get them from the same car will they need re-pairing?
    Also, do I need an additional aerial or something?
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    I swapped CD30 and BID for a paired CDC40 and GID without any fuss at all. I haven't got the separate DAB module (fits behind glovebox somewhere) nor the wiring loom nor the DAB aerial for it but I wasn't fussed about all that really, I just wanted the CD changer facility.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    If you want the CDC40 with working DAB you will need the headunit with screen and DAB module all from the same car for it to be plug and play. My facelift also needed the aerial loom from the drivers kick panel to the aerial on the roof and of course the DAB aerial base and mast too. Worth doing it all though!
    Cheers. If I didn't get the DAB unit or aerial..... would the radio still work or not?
    Feb 2011
    Trim : Sri
    Engine : 2.2 Direct
    Still get FM/AM ok, when you go through the menu to the DAB option you just see "DAB box error" displayed. Although I have to say that the FM reception on the '40 seems worse than on the '30.
    Norfolk
    Mileage : 69'000
    Mines definitely better than my old 30, looking to add an aux in next too!
    Thanks.
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Adding the aux-in should be easy if you are not going to use the DAB: http://www.vectra-c.com/forum/showthread.php?107617
  1. upgrading from cd30 to cd40
    By Djvec128 in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2012, 20:56
  2. cd30 to cd40
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2011, 16:09
  3. replace my CD30 with CD40?
    By domokun in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2010, 01:51
  4. CD30 - CD40 Dab Help
    By johnny1983 in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2010, 00:38
