Results 1 to 3 of 3
Thread: Faulty O2 sensor?
    Jan 2012
    Gloucestershire
    Default Faulty O2 sensor?
    On my 1.9cdti 150ps I've noticed my fuel consumption drop to 43-45mpg where I used to get nearer 48-50mpg.
    I've not got any engine lights/faults, other than because I currently have the EGR disconnected, but when I look at the live readings when idling I get the following for the O2 sensor:-
    B1S1 O2 Sensor heater temp 564 deg/c
    B1S1 O2 Sensor heater PWM 2%
    B1S1 O2 Sensor -5mV
    The -5mV makes me think the O2 sensor isn't working as it should. Anyone else seen this or can confirm if this is an O2 sensor fault? Also, is this likely to affect fuel consumption? I don't know how the ECU reacts to the O2 sensor readings.
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Check with a multimeter should switch between .2&.8v
    Jan 2012
    Gloucestershire
    Yes, good idea. Will do that this weekend if I get the opportunity.
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. faulty map sensor
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 16th February 2012, 20:51
  3. faulty lambda sensor
    By stephen g in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2011, 21:23
  4. help please faulty xbox kinect sensor
    By bigbrox in forum Games Room
    Last Post: 30th April 2011, 21:40
renault scenic o2 faulty
