Thread: Any CNC Milling Peeps on here - I need advise please.
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    Default Any CNC Milling Peeps on here - I need advise please.
    Hi, at work we have a few CNC Milling machines, such as the Fanuc Controlled Yang Eagle 600 and Eagle 1000 with a 20 Tool ATC.
    They are mostly used for metal working, but one is also used for machining plastic enclosures for us peeps in the Electrical Dept. We require batches of up to 250 at a time, with maching on upto 4 faces.
    Our biggest enclosure is 360mm x 254mm x 111mm.
    The max wall thickness is 4mm.
    The 360mm is the max height above the machine bed that needs machining.
    The smallest enclosure is 65mm on the longest edge.
    The drilling is up to 25mm diameter, plus tapping up to 20mm, and milling slots, etc.
    So I am trying to get the boss to look at a dedicated mlling machine for plastic, but I need to know what I a talking about.
    I have asked the machinist's but they just say they need more of the Eagle 600's or similar.
    They fit a maximum of 3 enclosures at a time into the machines, as they have 3 vices clamped to the table.
    I am thinking of a smaller machine, with more vices (or similar method of securing the work piece) and perhaps 10 tool ATC.
    So any thoughts??
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    Back to the top for further viewing.
    South east
    Try Googling "3D printing"
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    Thanks you, it's very interesting watching 3D printing.
    I wonder how soon after they invented the process did they make male or female body parts?
    However I need a subtractive process for my purposes.
    Regular Member Keif's Avatar
    In the Garage
    The smaller CNC Milling Machines i'm used to are normally Bridgeports, however it's not clear from you post what exactly you want.
    Do you want Set up and Machine one, then remove and set the next.
    or
    Set up one, start machining. While machining set up and 2nd.
    Machine 2nd, remove 1st unit and set another etc.
    Please make sure you get Fanuc control too.
    The business I used to work in had a DSG lathe with Fanuc, bought a 2nd DSG and had a different control system.
    Wasn't user friendly running both.
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    Quote Originally Posted by Keif View Post
    or
    Hi Keif, thanks for your input.
    I'm not sure, but probably the second option. I understand that is a sort of turntable operation with no ATC
    The set up at the moment is set up and machine 3 (3 vices, 3 boxes) then machine 3 more, etc., then, at end of batch, change program and machine the other box faces 3 at a time.
    I am at the limit of my knowledge about CNC's and I need to tell the boss my thoughts.
    Going to Google Bridgeports now.
    Very good point, thanks.
    In the Garage
    Quote Originally Posted by TonyP2020 View Post
    You can have an ATC with a twin table set up but having two "beds" you're talking big machine and big money.
    Cheaper option would be a small machine that does one piece at a time, but have a quick set up fixture. So turn round is quick and accurate.
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    Sounds good. Cheaper and smaller is what I'm thinking too. Any suggestions?
    In the Garage
    Unfortunately I only machined big stuff (between 1 and 2 meters in Diameter) so all the small machines where not CNC.
    Plus i've been off the duckboard for a couple of years now doing a Quality based job.
    Might be worth asking on www.cnczone.com
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    Thanks Mate, I will head over to cnczone.com
  1. hi peeps
    By jacko4 in forum Introduce yourself.
    Last Post: 1st September 2008, 22:30
  2. Hello peeps!
    By m0cea in forum Introduce yourself.
    Last Post: 10th August 2008, 12:38
  3. hello peeps
    By mr stroudy in forum Introduce yourself.
    Last Post: 25th June 2008, 09:25
  4. Hay peeps
    By vaux-j in forum Introduce yourself.
    Last Post: 3rd June 2008, 12:00
  5. Hi peeps
    By woody in shetland in forum Introduce yourself.
    Last Post: 22nd February 2008, 16:27
