Results 1 to 10 of 13
Thread: Vac gauge
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Default Vac gauge
    As above anyone no where to connect one up on a 2.2direct any piks would help Cherrs ladies and gents
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Any one ??
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    does it not go on the boost pipe? same thing but measuring in the opposite direction
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    No boost fella n/ a car am think about manifold
    Dec 2011
    Seaham
    Can you tee into the brake servo pipe?
    Jun 2012
    lancashire
    i know its normally aspirated that's why you get a vacuum as its sucking not getting blown by a turbo
    Mine registers a vacuum until the turbo kicks in then it switches to boost
    im using the sensor in the manifold to read both on torque pro
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is to permanent tee in is it Paul? If so you need to go into manifold or at least air intake pipes.
    If its for diagnostic purposes try teeing in on underside of throttle body.
    I've not seen that engine in person so don't know if its possible but its an idea.
    if its permanent fitted gauge get ya drill an tap& die set out lol
    Jun 2012
    lancashire
    sorry i shouldnt have said boost pipe i meant air pipe in to the manifold
    Regular Member hagga's Avatar
    kingswinford
    you can tee into anything after the throttle body to get your vac reading...not familiar with 2.2 but brake servo line/hoses off inlet manifold or flexi between tb and manifold... i wouldn't drill/tap stuff unless removed as swarf could be an issue(as getting sucked into valves/pistons)... if wanted a tempish thing would chop into brake servo pipe or depending on your diy capabilities drill through an m4-m6x20mm bolt 2.5-3mm and pop it through tb to manifold pipe with some rubber washers..if not temp would remove manifold and drill/tap.
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Cheers for the info lads that's whatbi was thinking just wanted to be shore lol hagga I think am ok lmao my capabilitys are not bad me thinks
  1. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  2. re boost gauge
    By davidjameswest in forum South Wales (RO - Vacant)
    Last Post: 19th March 2009, 01:00
  3. temp gauge
    By ptrehearn152 in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2009, 21:29
  4. Replies: 2
    Last Post: 15th September 2008, 23:18
  5. 0 gauge
    By kevster in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2008, 23:07
