Results 1 to 10 of 29
Thread: 2003 1.8 vectra c Brake power boost Valve
    Aug 2010
    London
    Default 2003 1.8 vectra c Brake power boost Valve
    Hi,
    I have had problems the last while with the car getting hard to start. It is random times. Other times the car starts ok. Another problem im also getting is engine light comes on and goes off which refears to the oxygen sensor 2(after cat performance).
    The other day the car was hard to start and when it did I drove for a short bit and when i got to the end of the road, the brakes where hard as a rock.
    I think it might be the power boost sensor. How do i release the pipe so i can check it????
    Would this also cause the engine to get hard to start if it was faulty????
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    really need the codes read on this
    could be cam or cranksensor
    or coilpack
    whats the mileage?
    have you got any codes
    Aug 2010
    London
    the codes where p0036-08 o2 sensor bank 1 sensor heated performance, and second was p0136-11 o2 sensor melfunction bank 1 sesnor 2.
    Milage is 82000. LAst 8 months it has been getting a lot of motor way driving. nerely 14000 in 8 months.
    Would this have an effect on the engine starting??
    Also how do i get the brake pipe removed from the throttle body to the master cyinder??
    Thanks Any help would be great. problem seems to be getting worse!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    sounds like the MAF sensor
    have read of this thread
    and read post 50
    http://www.vectra-c.com/forum/showth...ighlight=p0036
    Aug 2010
    London
    thanks for the link. I took a look and i tried that. I have just unplugged the MAF sensor and started my engine 3 times. The engine started perfect all 3 times. However this is what has been happening. The engine will start ok and then randomly get hard to start and then work again for a short while.
    Since my engine started perfect with the MAF disconected, do you still think this could be faulty??
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    post 51
    mark1892 disconencted his MAF while the engine was running ok and it made no noticeable difference, kept on running ok and in the end it was a faulty maf
    Aug 2010
    London
    Urmm ok. It says about cleaning the sensor. Can anyone recommend the best and safest way to clean it? Is brake cleaner ok ?? it is simalare to carb cleaner.
    Is £25.79 a good price for MAF of ebay???
    Thanks for your help
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    Is £25.79 a good price for MAF of ebay??? yes good price i have read somewere you can clean the maf but be careful what you use
    trying to find thread for you
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    is it more like a mis fire just for the first 30 secs
  1. help! no power steering vectra 2.0 diesel 2003
    By jay1989 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd April 2010, 13:36
  2. vectra c 2003 brake rattle help ?
    By sparks in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2010, 23:08
  3. Replies: 6
    Last Post: 3rd September 2009, 16:40
  4. Vectra C 1.8 Boost valve - Available Where?
    By CavScorpion in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2007, 09:43
