Results 1 to 10 of 19
Thread: 314 mm upgrade...
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Default 314 mm upgrade...
    I'm fitting the 314 mm brake upgrade to my vectra, I've got the calipers, discs and pads.... Do I need anything else like pad sensors etc.... Calipers have been sent off for sand blasting so I can paint em up,,
    Sent from my iPhone using Forum Runner
    South east
    Yea, you need the carriers.
    Aug 2009
    Got the carriers... Any idea if I need pad sensors or anything else..
    South east
    You'll probably need a new pad sensor because the old one will be very brittle (due to the heat from the brakes) where it connects to the pads, and may break when you try to remove it. Also, the sensor comes in two versions, one has a longer wire and most people find they need the longer one with the 314s; you'll have the shorter one at the moment on your car.
    Aug 2009
    Thanks pal.... I'll have to get some sensors then, any idea how much they are
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    had mine fitted 2 days ago, my sri didnt have any wear sensors. you deffo got them mate?
    South east
    Quote Originally Posted by 06sri View Post
    All Vectra-Cs have them, you'll find on yours that in the past someone has cut the sensor off the wire and connected the two wires together to complete the circuit and fool the system into thinking that the sensor is intact. Which means you'll need to keep an eye on pad wear because the sensor isn't there to tell you, any more.
    May 2012
    northumberland
    no, what that means is tommrow im going to investigate this futher my friend and put it back to what ever way it should be, what side would my sensor be on, as you have really upset me by telling me this lol.
    and is there one on the rear?
    Not one on the rear and the front one should Be on the passenger side of the vehicle
    Sent from my GT-I9300 using Forum Runner
    May 2012
    northumberland
    cheers, this has really p***ed me off hearing this.
    will the pad have to come back out when i buy a replacement sensor?
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. gid upgrade
    By booker413 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 16:48
  3. Looking to upgrade
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2010, 20:17
  4. upgrade on upgrade
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 23:27
  5. upgrade done what next ?
    Last Post: 19th April 2009, 22:46
