Results 1 to 10 of 15
Thread: Would you be happy or worried about this?
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Default Would you be happy or worried about this?
    I've seen a pre-face SRi 1.9 (120) that has caught my attention. I am half-considering a change to save some fuel costs.
    This is it's maintenance background -
    28/07/07 - 26,682 miles - Scheduled Service
    30/08/08 - 39,892 miles - Scheduled Service + Brake Pads All Around
    30/08/08 - 39,896 miles - MOT
    31/03/09 - 46,779 miles - New Turbo + Oil Service
    22/08/09 - 52,254 miles - Scheduled Service
    22/08/09 - 52,254 miles - MOT
    30/10/09 - 54,636 miles - New Althernator
    01/04/10 - 60,023 miles - Scheduled Service
    01/04/10 - 60,023 miles - MOT
    15/04/10 - 60,168 miles - New Flywheel Fitted
    11/10/10 - 61,748 miles - Scheduled Service Using Vauxhall Parts
    30/11/10 - 62,584 miles - New EGR Valve Fitted
    04/02/11 - 63,177 miles - Two New Front Shock Absorbers & EGR Cooler
    26/03/11 - 63,870 miles - Scheduled Service Using Vauxhall Parts
    28/03/11 - 63,889 miles - MOT
    13/05/11 - 64,500 miles - Four New Tyres + Four Wheel Alignment
    04/07/11 - 65,000 miles - Two Rear Coil Springs
    15/09/11 - 66,028 miles - Scheduled Service Using Vauxhall Parts
    18/03/12 - 68,223 miles - Scheduled Service Using Vauxhall Parts
    26/03/12 - 68,372 miles - MOT
    To you, does this scream "money pit that goes wrong a lot" or "well-maintained car that previous owners have looked after"?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Doesn't look to be anything out of the "ordinary" to be honest, and good that what has been replaced, has been replaced.
    I would very much put it in the "maintained regardless of cost" category
    Jun 2011
    wolverhampton
    I'd buy it as it's just had all the norm stuff done and there's nothing for you to do
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Quote Originally Posted by sriandy View Post
    Would agree
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    thats quite a nice maintaince background id of thought, dont appear to do many miles, which could indicate a local town shop / school run type of owner.
    South east
    The turbo change doesn't look "normal", especially at just 47,000 miles, and normally I'd be concerned that the turbo may have failed because the owner couldn't be bothered to have the oil changed before that, but the schedule shows it has indeed been serviced.
    HOWEVER - I would not accept a single print out as proof of any of this work having been done, or even a bunch of stamps in the booklet. I would insist on seeing the invoices; firstly because it's harder to forge a dozen documents than to forge just one, secondly because I would telephone several of the garages that have supposedly done the work and see if they have a record of the services in their computer system.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    im with dan blacksri on this one
    the turbo is the only one that sticks out being on 46779 miles but that would have cost money is there any invoices on that and why it was changed ?
    all the other bits like egr and alternator ive seen before break on this forum
    at least you havent got any swirl flaps to worry about
    how much is it?
    whats the year ?
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    TBH mate that's very much like the history of my Bora since I got it:
    WORK DONE SINCE I BOUGHT CAR DATE MILEAGE
    Forte ADT diesel treatment 01/01/09 107310
    MAIN SERVICE:
    Fuel filter
    Oil and filter
    Pollen filter
    Air filter
    Coolant temperature sensor
    Oil filter cover
    21/01/09 108404
    Brake fluid renewed 28/01/09 108672
    Cruise Control retrofitted.
    New n/s wiper arm
    17/03/09 110000
    OIL SERVICE:
    Oil and filter
    Fluids checked
    Air filter
    05/07/09 114926
    Four wheel alignment 03/09/09 117331
    NEW SUSPENSION COMPONENTS:
    Front lower wishbones
    Front and rear shocks and springs
    Front top mounts
    Rear bump stops.
    21/10/09 119411
    MAIN SERVICE AND CAMBELT:
    Cambelt and tensioner kit
    Water pump (plus coolant change)
    Oil and filter
    Air filter
    Alternator (aux) drivebelt
    Sundries as detailed on receipt.
    10/11/09 120142
    Clutch Replacement
    Dual-mass flywheel
    3-part clutch kit
    Release bearing.
    Clutch slave cylinder.
    17/03/10 122918
    Rear discs and pads 25/05/10 125724
    Main Service and New Sump Pan
    Fuel filter
    Oil and filter
    Pollen filter
    Air filter
    New sump pan.
    11/10/10 129760
    New Tyres x 4 and Tracking 27/10/10 130000
    New Catalyst, New Battery. 21/03/11 132345
    Front Discs and Pads 25/06/11 134495
    OIL SERVICE:
    Oil and filter
    Fluids checked
    Air filter
    26/09/11 136413
    New Suspension Components
    New rear springs – genuine VW
    New front anti-roll-bar bushes
    06/03/12 139204
    New front springs – genuine VW
    17/09/12 143134
    MAIN SERVICE:
    Fuel filter
    Oil and filter
    Pollen filter
    Air filter
    20/10/12 143820
    It's never broken down on me, I've just needed to replace worn out stuff.
    Feb 2011
    Trim : Sri
    Engine : 2.2 Direct
    Thanks for the replies, keep them coming. It's a late 2005, 55 reg. It's also wearing Vec-c.com stickers on the rear quarters, which makes me think it's more cared for than not.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I'd have it.
    My last CDTi (150) had a list as long as your arm of parts replaced. It gave no problems after they'd all been done
    Quote Originally Posted by Gubmint Agent View Post
    Post up part of the reg number and a pic, see who's it was
  1. getting worried now
    By slap204 in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2012, 23:12
  2. Am I worried over nothing
    By galway1 in forum Troubleshooting
    Last Post: 27th May 2012, 00:04
  3. Worried
    By nathkelly1983 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2012, 10:51
  4. worried!!
    By kpf1grandprix in forum General Chat
    Last Post: 21st June 2008, 20:02
  5. Should I be worried ??
    By ballogie in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2007, 23:49
