Results 1 to 10 of 13
Thread: thermostat change
    Jul 2011
    UK
    Year : 06
    Default thermostat change
    Would u change it ya self or take it to a garage drove down the motorway yesterday covering 40 miles and it sat just under 80 on the gauge
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    if it stayed at a constant temp and didnt drop back to the bottom again, i would say the thermostat is fine. Its when the needle goes up and then goes back to zero again you have a problem.
    Just remember this colder weather will stop your car reaching higher tempertures when driving.
    Jul 2011
    UK
    Year : 06
    It would go up to say 82 and drop below 80 again
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Would say that was normal. Especially if your in stop start traffic. The point with it being faulty is it went to 80 then dropped back to 0. If its fluctuating between a few degrees, then that is fine.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    the way i tested my thermostat was i turned the heater ( off ) i drove off from cold start the needle went to say 80 then i got on the motorway and it flat lined if never stuck at 86-89 (as previous)
    now i have a new thermostat fitted it stays at 86-89 and stays there and you get better mpg aswell
    if you do put heater number 4 on it will bring the temperature gauge down though
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    your thermostat sounds fine, mine was nackered when i got my car, it would hit 80 idling or slow moving traffic but as soon as you drive at speed it goes to 0
    Dec 2011
    Seaham
    I need to change mine, it works most of the time. It didnt like the cold morning this morning and refused to get anywhere on the gauge.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    They can take 5 -6 miles before the needle moves in this cold weather.
    Regular Member sscully's Avatar
    Jul 2011
    WALLASEY
    Vehicle : Vectra C Facelift
    Trim : SRI
    Engine : 1.9 Diesel
    Mileage : 89000
    If you were to change it recommend doing it your self I did few days ago just make sure you have a few jubliee clips as a few on the car cant be reused but were a ****** to take off. I followed the how 2 fron this site. job done and im not the best diy so if i can do it anyone can tbh
    Aug 2010
    Leeds
    Mine sits at 84 on motorway does go up slightly there does seem to be a lot of stress on critical temperatures on here if it works fine in summer it's likely to be fine in winter it's just the cold snap effecting it and the vectra does take a age to warm up.
    Try it with heater on cold and watch it get warmer faster and same driving up hills it should heat up quicker. -1 predicted locally tonight im working nights will take a while in the morning.
  1. thermostat change
    By vectra-man in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2013, 13:47
  2. thermostat change
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2012, 12:52
  3. thermostat change
    By smartalec0310 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2012, 17:54
  4. Do i change my thermostat?
    By beggsy in forum Engine & Drivetrain
    Last Post: 26th May 2012, 10:59
  5. How to change a thermostat 2.2
    By vx sri in forum Engine & Drivetrain
    Last Post: 22nd March 2011, 22:05
vectra c thermostat change
