Results 1 to 10 of 14
Thread: Drill Out DECAT?
    Aug 2012
    Default Drill Out DECAT?
    Is it possible to DECAT my CDTI by removing the CAT and knocking or drilling out all the gubbins. I seem to have pretty low power under 2000 revs and since it wont fail an MOT for not having a CAT I am thinking why not give it a shot?
    Thanks in advance
    J
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Yes you can do this i did it to my old CDTI and its still like that with the new owner.
    For low poer under 2000 revs have you tried cleaning your EGR valve and your boost senser i blanked my egr off and that solved my low power problem under 2000 revs.
    Aug 2012
    Hi Mark. The speed of your reply tells me to never post in the general troubleshooting area ever again lol ! Thank you very much for replying! I have tried cleaning the EGR and it was caked!!!! as was the MAP Sensor. However I am not sure the MAP sensor cleaned up to well and I may replace that before I resort to the CAT Drill. I just wanted to know if it was possible.
    Am I right in thinking the CAT is the bulge immediately after the turbo on the 120 8v?
    Many thanks again
    J
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Yeah its on the downpipe.
    Did you use carb cleaner and a tooth brush to clean the boost sensor i would advise blanking the egr and do the airbox mod that sure helped my old cdti and that was a 120 too.
    Aug 2012
    Quote Originally Posted by Mark-R View Post
    Yeah the MAP was totally encased in sludge but it still looked crusty when done as best I could (didnt want to damage it). It was after this cleaning that my turbo got loud and since worse and worse. Anyway the EGR was cleaned to and appeared to move freely. Would just unplugging it and then driving it tell me if it was to blame?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Just be careful if you drill it out/smash it out there's a sensor in the way! Better get that out first. At least, there is on the 150 engines. I'd blank out the EGR valve and smash out the pre-cat and remove the main cat again by either smashing it out or replacing it with a pipe.
    Hope you like diesel fumes! They stink until you get used to it!
    Aug 2012
    What is the pre-CAT and Main CAT? Whats the difference and where are they? If my car smells like a bus I am OK with it LOL as long as it goes like it should.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    The main cat is after the flex pipe and yes theres a sensor in the pre-cat i took that out before i attacked it with a big drill bit and hammer lol
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    this is what u attack lol http://www.ebay.co.uk/itm/vauxhall-v...item3a7ae95094
    and the big fat bit after the flex pip is the one u want to either bash out or cut off and replace with new bit of pipe
    http://www.ebay.co.uk/itm/Vauxhall-V...item27cc430216
    Aug 2012
    Ahh OK Cheers Guys! Thats some good info there and thanks to it I will most likely be making sure the EU fails its Pollution targets
    PS Thanks for the Pics Mark Very much appreciated - if a new MAP sensor don't fix it then that bit is gone lol!
    Cheers guys
    J
  1. Drill Out CAT - DECAT
    By jamesmcuk in forum Vectra C / Signum Troubleshooting
    Last Post: 24th October 2012, 22:32
  2. to decat or not to decat a gsi - is it worth it?
    By TimTay in forum Petrol Engine related
    Last Post: 21st January 2011, 21:25
  3. Replies: 16
    Last Post: 13th October 2010, 16:19
  4. need a new drill
    By neverlandandy in forum Comedy & Humour
    Last Post: 31st August 2008, 15:44
  5. We May have To Drill
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 12th February 2008, 15:59
