Thread: Sat nav into 04 elite
    Sep 2011
    essex
    Default Sat nav into 04 elite
    Hi hope all is well with all . Have a problem . Had a colour screen sat nav fitted in my dti elegance , when I sold the car I had it taken out . Got the guys in who fitted it before to fit it in my new 04 elite . The problem is that the display at the bottom of the screen that shows temp and fan speed does not show up on the main screen and when on the other screens for cd radio ect when you move the dials the display does show up , temp fan speed , but then goes after about 20seconds , they say they have wired it up the same as the how 2 on this forum ,and are now saying it may need tech 2 to reconfigure ? Any ideas ? Hope you can help .
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    what type of aircon did you have in the last car, is it the same type as in your new car? if you have gone from for example the 4 speed standard aircon to the 7 speed dual zone aircon (or the other way round) then you will need to configure this in the screen etc..
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    i recon the dti had 4 speed standard aircon
    and elite 7 speed dual zone aircon
    Sep 2011
    essex
    Hi I have the 4 speed blower and the2013 sat nav would this mean it needs tech 2 ?
    Jun 2009
    South Coast
    ok.. the old car, what year was it? what steering wheel controls do you have on 04 plate, the three button jobs or the two button and rollers?
    Sep 2011
    essex
    Quote Originally Posted by Caveman_nige View Post
    The old car was an 03 plate with the 3 button steering . The current car has the 3 button as well as I said the current car is an elite ( older style dash) same as previous car .
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Hmm so to clarify -
    we have gone from either climate control or semi-automatic air-con in the old car,
    to
    standard airconditioning in the new one - is that correct?
    If so, you shouldn't have any fan speed or temperatures in the bottom of your display.
    Standard (unregulated) air-con does not display information on the display module.
    Sep 2011
    essex
    Quote Originally Posted by Robsey View Post
    Hmm so to clarify -
    to
    Hi no it's the other way round new car has climate but it does display fan speed and temp but not on main screen just on radio cd and sat nav but only when you turn the temp and fan and will only be displayed for about 20 seconds then it goes .
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    In that case, you need to program the display to show that you have the correct type of "regulated" air-conditioning (ECC/SAC), as it will currently be set to unregulated standard air-con.
    Simple variance configuration setting change in the display - change from unregulated A-C to SAC / ECC.
    and also
    set the SAC/ECC as present in the mid-speed CAN programming tables.
    Other changes that may be required, depend upon whether you have changed fuel type or body shape.
    If you are using the same fuel type, and you have not changed from Estate/Signum to Hatchback / Notchback or vice versa, then no changes will be required with the code index value.
    Sep 2011
    essex
    and also
    So I need to get it tech 2ed then? Or is it in the wiring? Thanks.
  1. Off to look at a Signum Elite. Elite + suspension = GSI?
    By Yugguy in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2012, 10:42
  2. LS to elite
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2012, 13:03
  3. 2.8 elite springs on a 3.2 elite!
    By Ziggy in forum Handling & Braking
    Last Post: 12th April 2011, 18:51
  4. Bsr ppc 2.8t elite
    By LOCKSTOCK in forum Engine & Drivetrain
    Last Post: 12th September 2009, 22:00
