Likes Likes:  1
Thread: advice needed to complete retro fit of front park pilot
    east sussex
    confused advice needed to complete retro fit of front park pilot
    hi all, i have retro fitted the front and rear factory park pilot sensors to my 2007 exclusive the wiring loom plug at the front for the front harness is all their in place as is the headlamp washers plug and washer level all in place and working, i have had the car tech 2 the rear sensors are working fine with the switch on dash which lights up when in reverse gear and can be turned off, it all lights up with dash lights on, the vauxhall guy couldnt get the front sensors to work when he tech 2 the car, i have checked behind the battery cant see any wires missing or to plug into, does anyone know what i need to get the front sensors working? the kit i have fitted is the after market kit with the bosch sensors and the bosch control box fitted to the rec with the correct vx wiring. Any help would be most appreiated thanks in advance regards john.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    is it geniuen GM stuff? because then is should be a matter of selecting correct code index for the car.
    east sussex
    hi kenp thanks for your response and yes the kit is all the GM parts kit 93160432 and 93173965 with all the correct sensors and housings they sit in, the buzzer works fine and the chime under the dash makes a sound all ok the p symbol displays in the dash when the ignition is turned on and goes out with the other dash symbols, the vauxhall guy spent a lot of time on trying to program it but as already said could only get the rears working so im a bit miffed to know what to do next any more info would be much appreciated
    Engine : 2.2 Direct
    I can find the diffent code index for the car... but actually sound like the same problem at mine, where they tried to activate fronts.. ( i dont have teh front park sensors) and that failed..
    So actually its maby the modules for the OEM aftermarked kit thats the problem..
    east sussex
    ok kenp thanks for your reply and help, dont know if anybody else on the forum has any ideas
    Engine : 2.2 Direct
    Try to PM either Plasma or Tramman
  7. Likes s1mna liked this post
  8. #7
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    sounds like the body wiring that runs from the front under bonnet multiplug to the rear rec is missing in which
    case needs to be added and connected then the rear wiring youve fitted has to be re worked to make it to the
    proper wiring diagram
    the aftermarket wiring harness is only for rear park pilot only so thats why it needs to be completely altered
    the module is compatible for front and rear,its the wiring that needs sorting out.
    the index codes are -
    002 for front & rear (auto transmission)
    003 for front & rear (manual transmission)
    008 for rear only (auto transmission )
    009 for rear only (manual transmission)
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
  9. #8
    Engine : 2.2 Direct
    There are more Than those code index....
    Ive Got a list from 8 to 17 with different....
  10. #9
    east sussex
    thanks to kenp and andy.l for the info guys sounds a bit involved and behond me i think i will just leave them on the car for show they look good anyway
  1. For Sale: front preface bumper with park pilot
    By hairy31 in forum Parts for sale
    Last Post: 11th March 2012, 20:50
  2. Free: CD30 with Screen and Park Pilot front loom (preface)
    By LeeU in forum Parts for sale
    Last Post: 23rd September 2011, 13:29
  3. Front park pilot
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2010, 21:53
  4. Park pilot front parking sensor question.
    By tramman in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2009, 15:30
  5. FS: Complete Park Pilot set
    By Quinten in forum Parts for sale
    Last Post: 23rd September 2008, 19:34
vectra c front park pilot wiring
