Thread: VX Tyres Pressure vs. Tyre Warning...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Default VX Tyres Pressure vs. Tyre Warning...
    I see that Vauxhall recommend 44 psi on the front of 19" Snowies with the CDTi, and 39 on the back, but on the wall of the my tyres, it says do not exceed 40PSI !?!?
    Are the VX pressures too high, or should I put as much as I can in (40PSI)?
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Hmmm I run 39 all around in mine matey
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    Mate what tyres are you running? My sunnys say 44 or 46 on side wall im sure i run 40 all round so they dont crack lol. Would not go any lower than 38 like some people on here run 32 and 33 and they have had cracks
    Regular Member bigbnlr's Avatar
    Belfast
    I've always ran 42psi in my 18's, never had a problem
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    164 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    TBH with 19"'s and provided not more than 10% different, I would run the Vx pressure recommendations and next time you're replacing tyres, try to get ones with a higher limit. BUT, I would be taking a chance that the tyres would take the extra 10% and not the wheels which probably wouldn't survive a large pothole hidden by snow at more than 10 mph
    But, there again, I'm not a safety expert who I'm guessing would be telling you to get tyres that will withstand the Vx pressure ratings quoted LOL.
    I reckon these snowies were designed to look the part in Showrooms rather than "perform" on the road in the real world of GB roads
    Woody
    scottish region
    I have neutons 225/35/19 and run 36 front 33 rear
    I went with vxr fitted with 235/35/19 as I'm sure neutons say max 40 psi
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    I do about 44 front 40 rear... I always make sure its higher as I think it's under inflation that causes the cracking on snowies IMO.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Dont the neutons nt5000 have reinforced sidewalls? I keep mine on either 38 or 40psi all round.
    Oct 2006
    Waterloo, Liverpool
    10 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    No. Read the tyre sidewall again. 40 PSI is max pressure when mounting the tyre. Max pressure of tyre once mounted is commonly 50 or 51 PSI. Recommended rear tyre pressures when fully loaded in VX manual are as high as 51 on 19's (varies by engine type).
    You are worrying unnecessarily.
    Regular Member Jekyll & Hyde's Avatar
    Walderslade Woods,Kent.
    Check the manufacture of the tyre’s, as some of them ahave a recommended tyre pressure for the certain cars.
    Mine for exampleis running Vrednestein tyres, and they list my car 225/45/18 as 2.7bar-39.1 Psi(front) /3.0 bar-43.5 Psi(rear), as you can see this is way above the
    recommendations from the vauxhall hand book.
    Recommendations
  1. Tyre pressure warning light
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2012, 06:46
  2. Tyre pressure warning fault
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 19th June 2012, 00:58
  3. Tyre pressure warning light
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2012, 21:22
  4. Tyre Pressure
    By ed taylor in forum Suspension, Wheels & Brakes
    Last Post: 22nd November 2010, 11:36
  5. Tyre pressure
    By jun in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 21:17
