Results 1 to 10 of 26
Thread: 3.2 V6 Clicking on ignition turn.
    Warwickshire
    Default 3.2 V6 Clicking on ignition turn.
    Hi Guys,
    I sometimes get a loud clicking when I try to start the car, it will start first time, but after I run for about 3 miles if I park anywhere I then get this clicking.
    The battery is new, I have been told that it could be the starter motor. It depends on where the starter motor position is when I last started it sits.( if that makes sense). Noise is coming from the back of the engine, toward the floor.
    Hope you can advise me.
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    starters can click when failing, but on cars i have had in the past, when it clicks (starter motor) it normaly fails to start?
    Warwickshire
    Yes that's correct, when it clicks, it fails to start. Don't get the the clicking on starting the engine first thing.
    thank you.
    May 2012
    northumberland
    and you have 100% ruled out your battery, especialy on cold mornings? but yes pointing to starter motor, others will no doubt also advise before you start spending your money mate.
    Warwickshire
    100% not battery. Any ideas on a rough price for the job?
    cheers.
    May 2012
    northumberland
    depends first if you want gm starter or aftermarket, new or used or reconded, then should be able to give a rough estimate.
    Warwickshire
    I'll get a new one, not sure what you mean by gm starter or aftermarket.
    May 2012
    northumberland
    sorry ment one from vauxhall (original) or one from a normal parts supplier.
    Warwickshire
    Oh see what you mean, it'll probably be from parts supplier, so the cheaper of the two.
    May 2012
    northumberland
    this could be the one, please check before you buy it though, should be a hours labour at £35 to £50, there is no starter listed for your car in the vauxhall trade club.
    http://www.eurocarparts.com/starter-motor
  1. My CD70 won't turn on and off with ignition anymore?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 13:07
  2. Vectra 3.2 05 Gsi clicking noise when ignition turned on/off
    By bignew in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2009, 19:36
  3. buzzing noise after i turn ignition off?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2007, 10:20
  4. Clicking noise only when turning ignition
    By mbonnick in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2007, 07:10
  5. Stereo won't turn off with ignition?
    Last Post: 28th November 2006, 19:12
vectra 3.2 v6 starter motor failing
