Thread: One other thing... Auto levelling headlights
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default One other thing... Auto levelling headlights
    Is it a easy fit or specify only?
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    By Auto-levelling, I presume you mean Xenons, and Not Adaptive forward lighting. (AFL)
    Xenon's should be a do-able with the appropriate light clusters and ascociated cabling
    AFL's are listed as having a different part numbered / Alpha coded UEC modules (engine fuse boxes) in the Vauxhall electronic parts catalogue. So may be a bit more involved.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    What is afl? I dont understand it...
    And yes auto levelling so i dont worry about blinding drivers.. i havent adjusted the levels to proper sight as its quite low down on 0 position. I will do the level adjusting soon as i could.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    AFL - adaptive forward lighting - where the lights bend to the side as you are turning.
    Auto light levelling sounds like the Xenon option.
    According to Vauxhall's technology page
    AFL makes night driving safer and less stressful by enhancing visibility through curves and sharp bends. The movable elements in the intelligent, bi-xenon headlights automatically adjust themselves to different conditions, ensuring safer and more relaxed driving. Nine different light functions make the best of every situation, improving road illumination by up to 90% – without dazzling other drivers
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Yes, AFL needs a lot of modifications in loom, costy additional (or replacement) modules, etc.
    Auto-levelling for simple xenon is easier, though you still may need to modify the loom and/or headlight (if for instance you have fitted HID bulbs in standard dual H7 headlamps), as you'll need an additional CAN bus wire to the levelling motors.
    You'll find some hints in Kenp's pre-face xenon headlights retrofitting description :
    http://www.vectra-c.com/forum/showth...o-fitted/page9
  1. Levelling headlights post HID install?
    By bigdave1701 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd September 2011, 17:03
  2. GSI AFL self levelling headlights - fault
    By Padster72 in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2010, 14:19
  3. new springs and auto levelling headlights
    By animal22 in forum Suspension, Wheels & Brakes
    Last Post: 22nd November 2009, 19:50
  4. auto headlights, fog lights and levelling system not working
    By jong in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2009, 08:22
  5. Xenon Headlights Auto Levelling Issue
    By bigstevex in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2007, 21:14
