Results 1 to 10 of 25
Thread: Daylight headlight
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Daylight headlight
    Heres the option in the computer for daylight option. Its disabled at minute but wanted to know does it mean it's headlights on all time anytime when running the car? Bit like volvo? Lol
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    For the front, with the light switch set to off - version 1 = side lights on with ignition; dips come on as soon as engine started.
    version 2 = side lights and dips come on as soon as ignition is on.
    The headlight switch will function as normal in the other positions.
    Versions 3 & 4 do nothing.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Super.thats what i needed to know :-) quite like the 1st setting as i like to have HIDs on all time. Anyone object to this idea??
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    174 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    4 activated my front foglamps only at reduced light as DRL's (Car is a 2004 pre-face 3.2 Gsi with factory fogs)
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by woodpeck View Post
    That's an idea. It might work without BCM activation for time being? Just a hopeful thought
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Yes, it has to be activated in the UEC only.
    It even doesn't ask for the car security code !
    May 2012
    174 Post(s)
    Mileage : 131,000
    Quote Originally Posted by Z80 View Post
    I'm just guessing, but I would expect the foglamp DRL option 4, only to work, when the foglamps are capable of working normally.
    As said, just guessing though.
    Apr 2008
    Noumea
    14 Post(s)
    Trim : Elegance
    Mileage : 75 000
    Here is what mine does :
    Options 2 and 3 : low beams
    Options 1 and 4 : nothing
    Strange...
    May 2012
    174 Post(s)
    Mileage : 131,000
    That is strange, I couldn't see any change when I first used option 4 on mine either. I must say that I was concerned that changes made via the unit I was using might be "risky" so I was extremely cautious about trying them. When I did, I thought I had it working, I then disconnected the kit, and then restarted things, only to find that I didn't have anything working as expected after all.
    So, I tried again and duplicated the original process.
    Voilla, it worked.
    At some point from originally programming the selection, to disconnecting the equipment,after the changes, something had stopped the setup from working. I then discovered that whilst programming with the unit attached, all seemed to work, but when the programmer was disconnected it stopped working,.......... until I started the engine that is.
    It seems that when programming with the unit attached, things work with just the ignition on, but once disconnected, the option only starts to work once you start the engine.
    Sorry I can't be more specific, but I had the sense of failure originally, because all seemed to work with the engine off, but once I disconnected, everything I had done had stopped working..............After starting the engine, all was ok.
    Apr 2008
    Noumea
    14 Post(s)
    Trim : Elegance
    Mileage : 75 000
    Just read that after repogramming, you should turn ignition off for 30 seconds and unplug the Op-Com. I'll try again this way...
    I also remember having to do it twice when I programmed my flip-key.
  1. Daylight Running Lights – DLR’s
    By coldo in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2012, 22:14
  2. They want locked up and never to see daylight again
    By marc vectra sri in forum General Chat
    Last Post: 29th June 2012, 18:04
  3. Irmscher Daylight Plus DRL Kit
    By watchman in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2011, 19:05
  4. Irmscher Daylight plus
    By bigmac in forum Styling
    Last Post: 7th August 2011, 00:55
  5. daylight saving clock help
    By robhullfury in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2007, 16:38
