Thread: Door trigger
    Nov 2010
    Maidstone
    Default Door trigger
    Hi all, hope you can help with something, im in the middle of fitting an alpine roof monitor and it requires either a positive or negative door trigger, where could i get this from as i think the roof lights are fed via ribbon which will be a right git to get onto, any ideas?
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Not sure on the doors but between the ribbon block and circuit board it turns back into wires if you want to splice into them...
    Nov 2010
    Maidstone
    Is there enough meat to solder onto?
    21 Post(s)
    Mileage : 110k
    Yeah a good couple inch of wiring...
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    can the 12v for the ashtray bulb feed be used for this
    21 Post(s)
    Mileage : 110k
    Not sure it's powerful enough as people have had issues even powering LED's, plus no need to mess about feeding down the A pillars...
    Pretty sure the grey/brown is a negative trigger IIRC.
    Nov 2010
    Maidstone
    I dont mean to insult your intelligence but are you sure its negative trigger on these, my old astra used to be but not sure sure on newer vauxhalls? I dont suppose you have a wiring diagram for the 4 wires involved as ive established brown is constant live, brown/white is live when main stwich is flicked (guessing this goes back to rear lights courtesy lights also), but not sure on the other 2, any help greatly appreciated as ill be sorting the wiring tomoz after work so need to get my head straight with it. Many thanks
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by signum_rob View Post
    Solid brown is always earth on Vectras unless yours has had some custom wiring done.
    Nov 2010
    Maidstone
    Oh i see, have you any idea what the other colours are for?
    Nov 2010
    Maidstone
    Anyone any ideas?
  1. z20net trigger wheel help!
    By si.c1978 in forum Petrol Engine related
    Last Post: 19th April 2010, 18:35
  2. Does faulty EGR trigger any error codes?
    By markluk in forum Engine & Drivetrain
    Last Post: 24th March 2009, 22:47
  3. Recycling Irmscher Door Sill Plates and Door Pillar Trims
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2008, 19:08
  4. Do speed cameras sometimes false trigger?
    By Duncan in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2006, 16:19
