Thread: cdti sri throttle body butterfly
    Oct 2012
    liverpool
    Default cdti sri throttle body butterfly
    Hi guys new to the forum an just got meself a cdti 1.9 (120). After owning 3 ford focuses an having 3 steering problems I thought time for somethin new. Got this for 1k as the seller said suspected turbo fail. Ran diagnostic in whichpointed to the pcb which controls the butterfly in body. Anyway I opened up an was absolutely full of oil to which I blasted cleaner in until spotless and car ran spot on. But this mornin it ran as in no turbo again an fault code said was this again. Sorry for going on but I suspect oil. On the contacts again. I've resoldered connections to. Does anybody know if there is a better way to seal this body part? Thanks guys
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Best remove the throttle body and clean it with carb cleaner. Make sure EGR is clean too
    Oct 2012
    liverpool
    I did them both an egr moving freely. Can diesel or oil actually makes it way down the butterfly shaft into the pcb inside?
    Oct 2012
    liverpool
    Also abit off topic but are all 1.9 chips the same e.g cdtiastra fit vectra, does 120 fit 150 version? Thanks
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by seddo View Post
    Yes it can but the problem on the earlier cars was more related to broken solder joints on the throttle body PCB.
    What is the fault code?
    Oct 2012
    liverpool
    The code was 1125 just annoying I wish there was a better seal
    Regular Member tosh23's Avatar
    HULL
    The butterfly is an anti judder valve, Take off the corrugated right angle tube that goes from egr to throttle body lookalike, it will be gunk ed up, Some people have had oil residue in the bottom of the black box but as previous post says, dry joints are the main problem, Have another look in the black box, I dont think it would gunk up so quickly.
    have you cleaned your boost pressure sensor ?
    Oct 2012
    liverpool
    Cleaned boost sensor last night but I've come to another conclusio. I drove car after work an it began to work again but this mornin it stopped again. Could it be down to damp or cold in some connections in that area? Anybody else had this happen to them like this?
  1. Throttle body butterfly plate removal (someone had to do it)
    By diesel dog in forum Diesel Engine related
    Last Post: 15th March 2012, 12:52
  2. How to clean the throttle body of CDTi 1.9?
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2011, 13:03
  3. throttle body butterfly cdti 150
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2011, 17:47
