Thread: Stuck Glow plugs
    Merseyside
    Default Stuck Glow plugs
    Been trying to change the glow plugs on my 150 diesel. Slackened them all off with a 9mm socket but only number 3 will acutally come out - its like the others are trapped inside the cylinder head.
    The engine is still warm, so is this the cause of them being seeming trapped or is there something else?
    How can I get them out?!?!
    Engine : 1.9 CDTi
    Engine warm is good.
    Do they turn at all?
    Give them (And keep giving them) a soaking of penetrating fluid.
    Merseyside
    Quote Originally Posted by lee gsi View Post
    I've managed to get 1, 2 and 3 out and changed them now. 4 turns until the thread is fully exposed but it just wont come out at all. I can see that there is nothing apparently holding it in so just about to result to brute strength to pull the blighter out. Soaked it in penetrating oil but it wont shift it once the thread is totally loosened off. Stupid thing!!
    Merseyside
    I've managed to get 1, 2 and 3 out now and replaced them. 4 still wont release itself after I've completely undone it. Doused it it penetrating spray and left it for tonight. Will have another go tomorrow morning in work, but what else can I do to get the blighter out? Don't want to end up paying half hours labour for 1 glow plug!
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by signum_1.9 View Post
    Cover the glow plug area with a protective mat / towel / blanket.
    Crank the engine to see if it pop's out under compression, but dont run the engine.
    Be careful though please.
    Jun 2009
    birmingham uk
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Mileage : 106000
    Not the best way or recommended way to get it out but as long as the threads are clear and you have some padding to catch it well secured above the glow plug if you turn the engine over as the engine starts the glow plug will be blown out with LOTS of force. Like a bullet out a gun! Needless to say kill the ignition as soon as it starts.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    what happens is the end of the glow plug swells up a bit stopping it from coming out. If you twist and pull at he same time you should wear the end down enough to get it out. just take your time and keep turning and pulling.
    Merseyside
    Quote Originally Posted by C-Owner View Post
    Quote Originally Posted by merikiito View Post
    tried all these methods this morning and it won't budge at all, even using the compression method. I've changed 3 of them and it starts much easier now. Will just leave this one alone and hope it doesn't cause any issues in the future.
  1. I need new glow plugs
    By CH-VECTRA-ELITE in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 09:48
  2. East Midlands Stuck Glow Plugs
    By John Bishop in forum Engine & Drivetrain
    Last Post: 2nd March 2012, 19:43
  3. glow plugs stuck
    By melvyn8181 in forum Diesel Engine related
    Last Post: 8th December 2011, 21:27
  4. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  5. my stuck glow plug... cowboy garage....
    By fireman00067 in forum Engine & Drivetrain
    Last Post: 2nd April 2009, 07:04
vectra 1.9 glow plug keeps turning but wont come out
vauxhall insigina glow plug wont come out
vectra heater plugs stuck
how to get stuck glow plugs out vectra
vauxhall vectra c heater plugs stuck
vectra c glow plug free but wont come out
vectra glow plug stuck
