Results 1 to 10 of 16
Thread: 07 SRi Sluggish
    Jul 2012
    Orkney Isles
    Default 07 SRi Sluggish
    I have been noticing that the Wife's 07 SRi goes like stink in first gear but in 2nd 3rd etc it is not near as nippy - when the throttle is put to the floor it just doesn't take off like you would expect - any ideas ?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Which engine?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    what engine do you have as SRi normally just means low trim spec but 15mm lower
    Jul 2012
    Orkney Isles
    Sorry, it's the Z18XER.
    Jun 2009
    South Coast
    ok, the 1.8vvt, good engine. When was the fuel filter, spark plugs and air filter last changed?
    Barrow In Furness, Cumbria
    Mine doesn't really go much in second and third. Still moves like but as soon as you change from first to second it doesn't pull like other cars do that I've owned.
    Its almost like the ECU limits the amount of power hitting the gearbox when you change gear at high revs.
    Jul 2012
    Orkney Isles
    Yes that sounds about the same.
    Just got the car in July so don't know when any of it was changed exept the timing belt - although the guy that I bought it from said he would give it a service ???
    Sounds normal then.
    Hard to describe but it doesn't pull your head back when changing from 1st to 2nd at high revs. Almost like it bogs down for a second or so.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    i would do the air filter to start with
    try the air filter mod type that into the search
    Jul 2012
    Orkney Isles
    Tried searching for air filter mod but can't seem to find it - have been reading about air box mod as in the trumpet part being cut off or taken out ?
  1. sluggish
    By iokarus in forum Engine & Drivetrain
    Last Post: 29th February 2012, 20:35
  2. Sluggish again
    By durham4416 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 18:20
  3. sluggish
    By chrosty in forum Diesel Engine related
    Last Post: 29th December 2010, 23:55
  4. sluggish 1.9 cdt
    By thommo in forum Introduce yourself.
    Last Post: 16th March 2010, 14:57
  5. Car feels a bit sluggish
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 23rd March 2009, 09:28
