Thread: abs light/sensor
    Regular Member stret's Avatar
    Oct 2012
    east midlands/westmidlands
    27 Post(s)
    Vehicle : signum
    Trim : elite
    Engine : 1.9 cdti 16v 225bhp
    Year : 54
    Mileage : 150k
    Default abs light/sensor
    had abs light on had it scanned and code was front n/s sensor replaced hub/sensor cleared fualt and it came straight back on any ideas what i should do next?
    thanks
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Take it for a drive an conform reading or not.
    check connectors/wiring for resistance
    Oct 2012
    27 Post(s)
    Vehicle : signum
    Trim : elite
    Year : 54
    Mileage : 150k
    how do i check for resistance?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Voltage drop on cable or use an ohm meter
    Oct 2012
    27 Post(s)
    Vehicle : signum
    Trim : elite
    Year : 54
    Mileage : 150k
    i have an ohm meter so do i need to spin hub while testers on if a get a change in reading its not the sensor?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    What diagnostic equip do you have?
    spin to check for voltage.
    Check for ohm reading through sensor an through wiring into ecu
    9/10 its corrosion at connectors
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    Could be the speed sensor wiring connector has got water in it. Fairly common problem for the front left wheel. Have a look behind the hub and you will see the sensor wire clipped into the suspension leg. Disconnect the wiring plug and see if there is water in it, dry and refit may solve the problem. Worth doing on both fronts.
    a member on here had water in the connection and caused abs light to show.
    Regular Member paul-west-76's Avatar
    Feb 2011
    wolverhampton
    Vehicle : signum 1.9 cdti 150
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    where did you get the new hub from?? i had same issue and went for a cheapo part from ebay and was poor quality, didnt solve problem, ended up getting original part, cost more but sorted problem straight away.
    Oct 2012
    27 Post(s)
    Vehicle : signum
    Trim : elite
    Year : 54
    Mileage : 150k
    problem is now sorted it was indeed a coroded cable cut it out solered back together and fault cleared so prob never needed the hub after all but nevrmind sailed through its mot so im happy <br><br>thanks guys
  1. Rain/Light Sensor Fit
    By Aidi in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2012, 19:17
  2. Spanner Light Cam Sensor?
    By 11mallard in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2011, 19:51
  3. Spanner light ( map sensor maybe ? )
    By eddy in forum Engine & Drivetrain
    Last Post: 30th December 2009, 18:06
  4. Dodgy Light Sensor...
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2007, 13:25
