Thread: Fiat gaskets for EGR valve
    Aug 2012
    berkshire
    StatsVehicle Info
    Default Fiat gaskets for EGR valve
    looking through the post, seems like the Fiat gaskets for EGR valve on a 1.9 cdti 150 is worth doing as it helps to reduce the build up into the inlet manifold?
    but 2 questions, might sound silly, but is this not just letting it all build up in the pipes before it enters the inlet manifold?
    i have heard than it throws up the spanner light and somethings the engine managment light? is this true?
    Lancashire
    StatsVehicle Info
    Are you bothered about EML or emissions light?
    If not, then I recommend you blank it completely.
    Regular Member Ziggy's Avatar
    Leeds
    StatsVehicle Info
    MOT man is though. and would you not risk missing an actual issue. Best better is to blank and map out the egr.
    StatsVehicle Info
    The same amount pass's through but because there are restrictions the soot pass through at a higher pressure so dont cool as quick and get stuck in the egr.
    It helps but dosent cure all egr problems.
  1. Gaskets
    By Chuddy in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2011, 12:50
  2. EGR valve gaskets
    By melvin in forum Troubleshooting
    Last Post: 12th October 2010, 19:24
  3. Replies: 12
    Last Post: 17th May 2010, 22:21
  4. egr valve gaskets /part numbers
    By cranny 27 in forum Engine & Drivetrain
    Last Post: 2nd May 2010, 18:44
  5. Fiat EGR gaskets fitted now i have problems!
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2010, 16:15
fiat 248 valve gasket
