Results 1 to 3 of 3
Thread: Oops!! Snapped the seatbelt bolt!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Oops!! Snapped the seatbelt bolt!
    As above! For rear seatbelt bracket and tenision (held down for left and centre belts.
    I took it out. Was a easy process. (changed seats) put bolt back on. Tight... So took it out and retried. Tight. Thought it was weird. So tried again. Thinking maybe tight first then easy but no it snapped !!! Now i have a snapped half stuck in the thread hole. No way to grip remove as its inside the hole to bolt area.
    Any advice? Weld the belts down??
    I have this...
    But dont know if it'll bring it out as was tight going in!!
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved again ! Please stop posting everything Vectra c chat
    Irmscher Insignia CDTI 130
    Dec 2011
    Seaham
    You can only try them, you need to carefully drill a pilot hole in the sheared bolt, make sure you have a good drill bit, then try the removers.
    I have done it successfully on other cars. Or, carefully drill the bolt out with wider and wiser drills then retap the thread.
  1. Snapped tensioner bolt, help :(
    By danny2009 in forum Engine & Drivetrain
    Last Post: 29th April 2013, 17:14
  2. Snapped a bolt ,,,,hahaha
    By collyb in forum Engine & Drivetrain
    Last Post: 6th June 2011, 23:53
  3. bolt snapped
    By tappetpaul in forum Engine & Drivetrain
    Last Post: 14th March 2011, 23:43
  4. Snapped Bolt
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2009, 14:06
  5. Snapped Wheel Bolt
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 10:17
