Results 1 to 2 of 2
Thread: Getting serious now....not running at all cdti 150
    Sep 2010
    Plymouth
    Engine : 1.9 CDTi 150
    Year : 06
    Mileage : 250,000
    Default Getting serious now....not running at all cdti 150
    Help please,
    having replace the core plug I have put everything back together, that includes.....
    alternator
    fuel pump
    extension housing
    oil cooler
    it has has a new timing belt and water pump, the timing marks haven't moved from when I took the old one off.
    start the car and it turns over, runs for a spilt second and dies, it sounds like fuel delivery, I have fuel at all the injectors but I am wondering if if is not getting into the engine at the right time!!
    now I was led to believe that the cdti engine don't have pump timing, can someone confirm this please, and if there are any ideas on what this issue could be please can you help.
    thanks
    Jan 2012
    Gloucestershire
    HP pump doesn't need to be timed because all it does is pressurise the common rail. However, it does need to be working properly to get sufficient pressure into the rail for the injectors to function properly to get enough fuel into the cylinders.
    Camshaft sensor is used to position injector timing once the engine is started - crankshaft sensor is used during startup. So, maybe your camshaft sensor isn't working properly?
  1. CDTi 150 Running Temperature
    By tony-1977 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 11:38
  2. CDTI 120 running issues.
    By Slammedorion in forum Engine & Drivetrain
    Last Post: 22nd March 2012, 13:31
  3. cdti running badly
    By toast in forum Engine & Drivetrain
    Last Post: 12th March 2011, 19:49
  4. 1.9 CDTI (either flavour) running on its own?
    By slindborg in forum Engine & Drivetrain
    Last Post: 7th May 2010, 09:45
  5. CDTi running temp ?
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 27th February 2009, 15:01
